12.1.4. Chemical reactions
12.1.4.1. ARRHENIUS_RRATES_DES
Flag to use Arrhenius reaction model for discrete particle reactions.
12.1.4.2. ARRHENIUS_RRATES_FLUID
Flag to use Arrhenius reaction model for fluid phase reactions.
12.1.4.3. CHEM_MIN_SPECIES_FLUID
Minimum species mass fraction in fluid. Reaction rates are not calculated when reactants fall below this threshold.
12.1.4.4. CHEM_MIN_SPECIES_SOLID
Minimum species mass fraction in solid. Reaction rates are not calculated when reactants fall below this threshold.
12.1.4.5. NMAX(PHASE)
  • 0Phase10
12.1.4.6. SPECIES_NAME(PHASE)
  • 0Phase10
12.1.4.7. STIFF_CHEM_ABS_TOL
12.1.4.8. STIFF_CHEM_MAX_STEPS
12.1.4.9. STIFF_CHEM_MIN_RATE
Stiff chemistry minimum fluid reaction rate. If all fluid reaction rates are below this threshold, a cell is said to be non-reactive and no ODE is set for this cell.
12.1.4.10. STIFF_CHEM_MIN_RATE_DPM
Stiff chemistry minimum DPM (Discrete phase model) reaction rate. If all DPM reaction
rates are below this threshold, a particle/parcel is said to be non-reactive and no ODE is set for this particle/parcel.
12.1.4.11. STIFF_CHEM_REL_TOL
12.1.4.12. STIFF_CHEMISTRY
Flag to use stiff chemistry solver (Direct integration).
12.1.4.13. USE_RRATES
