12.1.18. Thermochemical properties
MFiX uses the Burcat or NASA 7-Coefficient polynomials to calculate thermochemical properties of species (not the NASA 9-Coefficient polynomials). The directory model/thermochemical contains the database of Burcat and Ruscic (2005) and routines for reading the database. With linkage to this database the users need not manually enter data for molecular weight, specific heat, and heats of reactions. Instead the users only need to enter the names of the species (keyword SPECIES_g and SPECIES_s) in the data file. If such information is already provided in either the data file or a BURCAT.THR file in the run directory then MFiX will not reference the database. That is, MFiX reads the necessary thermochemical data from files in the following order:
  1. mfix.dat or *.mfx
  2. BURCAT.THR file in the run directory
  3. model/thermochemical/BURCAT.THR
The species names are case sensitive and should match the names in BURCAT.THR exactly; alternatively aliases can be defined for common species, such as O2, in read_therm.f. See tests/thermo for a sample case that accesses the database. The format of BURCAT.THR file resembles CHEMKIN format, but with several notable differences. To include thermochemical data in the mfix.dat file then this information must start below a line that starts with THERMO DATA.
../_images/burcat.png
Table 12.90 Coefficients
\(a^1_H\)
\(a^2_H\)
\(a^3_H\)
\(a^4_H\)
\(a^5_H\)
\(a^6_H\)
\(a^7_H\)
\(a^1_L\)
\(a^2_L\)
\(a^3_L\)
\(a^4_L\)
\(a^5_L\)
\(a^6_L\)
\(a^7_L\)
\(\frac{\Delta H^{\circ}_f}{R}\)
\[\frac{C_p}{R} = a_1 + a_2 T + a_3 T^2 + a_4 T^3 + a_5 T^4 .\]
\[ \begin{align}\begin{aligned}\frac{H_T}{RT} = a_1 + \frac{a_2 T}{2} + \frac{a_3 T^2}{3} + \frac{a_4 T^3}{4} + \frac{a_5 T^4}{5} + \frac{a_6}{T}\\\frac{S_T}{R} = a_1 \ln{T} + a_2 T + \frac{a_3 T^2}{2} + \frac{a_4 T^3}{3} + \frac{a_5 T^4}{4} + a_7\\\frac{G_T}{RT} = \frac{H_T}{RT} - \frac{S_T}{R}\end{aligned}\end{align} \]
Instead, MFiX integrates \(C_p\) to determine changes in enthalpy. See Burcat Introduction document for more details, which is also included in the source, model/thermochemical/intro.pdf.
Additional database comments:
  • A number of species in the database have a lower temperature limit of 300K which is 2 degrees above the reference temperature (298 K) used for formation enthalpy calculation. For those species MFiX relaxes the lower limit for \(C_p\) calculations to 298 K to enable heat of reaction calculation (see read_database.f).
  • The database reader is set up such that the database is read only if necessary.
  • If you include thermochemical properties in mfix.dat all keywords defined below the line that starts with THERMO DATA will be ignored!
