12.1.16. Run control
12.1.16.1. AUTO_RESTART
12.1.16.2. DES_RIGID_MOTION(PHASE)
Prescribe rigid body motion to particles belonging to this phase. Default value is .FALSE., meaning the particle motion is computed by integrating acceleration to velocity and velocity to position.
12.1.16.3. DES_RIGID_MOTION_OMEGA(PHASE, COMPONENT)
  • \(1 \le Component \le 3\)
Particle rigid motion angular velocity. The first index is the phase ID, the second index is the component (1=x, 2=y, 3=z)
12.1.16.4. DES_RIGID_MOTION_ROT_CENTER(PHASE, COMPONENT)
Particle rigid motion center of rotation. The first index is the phase ID, the second index is the component (1=x, 2=y, 3=z)
12.1.16.5. DES_RIGID_MOTION_VEL(PHASE, COMPONENT)
Particle rigid motion translational velocity. The first index is the phase ID, the second index is the component (1=x, 2=y, 3=z)
12.1.16.6. DESCRIPTION
Problem description. Limited to 80 characters.
12.1.16.7. DRAG_C1
12.1.16.8. DRAG_D1
12.1.16.9. DRAG_TYPE
Table 12.69 Valid values
BVK
DIFELICE
DIFELICE_GANSER
GAO
GIDASPOW
GIDASPOW_PCF
(TFM only). see GIDASPOW
GIDASPOW_BLEND
GIDASPOW_BLEND_PCF
HYS
KOCH_HILL
KOCH_HILL_PCF
(TFM only). see KOCH_HILL
QKQY
  1. Qi, S.B. Kuang, T.S. Qiu, A.B. Yu, Lattice Boltzmann investigation on fluid flows through packed beds: Interaction between fluid rheology and bed properties, Powder Technology 369 (2020) 248-260 and S. Benyahia, Simulation of heavy particles fluidized with non-Newtonian fluids, Powder Technology 433 (2024) 119261
RADL
SARKAR
SQP_DIFELICE_GANSER
Xi Gao, Jia Yu, Liqiang Lu, Cheng Li and William A Rogers, Development and validation of SuperDEM-CFD coupled model for simulating non-spherical particles hydrodynamics in fluidized beds, Chemical Engineering Journal, 2021,420: 127654. and G.H. Ganser, A rational approach to drag prediction of spherical and nonspherical particles, Powder Technol. 77 (1993) 143-152. This model requires specification of a sphericity and a reference length (typically the bed diameter)
SQP_DIFELICE_HOLZER_SOMMERFELD
Xi Gao, Jia Yu, Liqiang Lu, Cheng Li and William A Rogers, Development and validation of SuperDEM-CFD coupled model for simulating non-spherical particles hydrodynamics in fluidized beds, Chemical Engineering Journal, 2021,420: 127654. and A. Hölzer, M. Sommerfeld, New simple correlation formula for the drag coefficient of nonspherical particles, Powder Technology 184 (2008) 361-365.
SYAM_OBRIEN
WEN_YU
TGS
TPKKV
WEN_YU_PCF
(TFM only). see WEN_YU
USER_DRAG
12.1.16.10. DT
12.1.16.11. DT_FAC
12.1.16.12. DT_MAX
Maximum time step size.
12.1.16.13. DT_MIN
Minimum time step size.
12.1.16.14. ENERGY_EQ
Solve energy equations.
Table 12.70 Valid values
12.1.16.15. FILTER_SIZE_RATIO
12.1.16.16. ISHII
Table 12.71 Valid values
Default form.
12.1.16.17. JACKSON
Table 12.72 Valid values
Default form.
12.1.16.18. KEYFRAME(KEYFRAME FILE ID)
  • \(1 \le Keyframe file ID \le 100\)
Read a keyframe data file. Example: KEYFRAME(3) = .TRUE. will read the keyframe file keyframe_0003.csv. The first column of keyframe_0003.csv stores the independent variable. The next columns of keyframe_0003.csv store the dependent variables.
Table 12.73 Valid values
Read keyframe data file.
Do not read keyframe data file.
12.1.16.19. KF_INTERP(KEYFRAME FILE ID)
Keyframe interpolation method (applies to all variables in a Keyframe datafile. Example: KF_INTERP(3)=’LINEAR’ First index (3) means the keyframe data file is keyframe_0003.csv.
Table 12.74 Valid values
LINEAR
Linearly interpolate data between keyframes (default).
STEP
Keep data constant between keyframes.
12.1.16.20. KF_KEYWORD(KEYFRAME FILE ID, COLUMN NUMBER IN CSV KEYFRAME FILE)
  • \(1 \le Column number in CSV keyframe file \le 20\)
Name of keyword controlled by a Keyframe datafile. Example: KF_KEYWORD(3,1)=’bc_v_g’ First index (3) means the keyframe data file is keyframe_0003.csv. Second index (1) means the first dependent variable (second column) controls keyword bc_v_g. See documentation for list of keywords that can be controlled by a keyframe.
12.1.16.21. LAM_HYS
12.1.16.22. MODEL_B
Shared gas-pressure formulation. See Syamlal, M. and Pannala, S. “Multiphase continuum formulation for gas-solids reacting flows” chapter in Computational Gas-Solids Flows and Reacting Systems: Theory, Methods and Practice, S. Pannala, M. Syamlal and T.J. O’Brien (editors), IGI Global, Hershey, PA, 2011.
Table 12.75 Valid values
Use Model A. See Bouillard, J.X., Lyczkowski, R.W., Folga, S., Gidaspow, D., Berry, G.F. (1989). Canadian Journal of Chemical Engineering 67:218-229.
12.1.16.23. MOMENTUM_X_EQ(PHASE)
  • \(0 \le Phase \le 10\)
Table 12.76 Valid values
Solve X-momentum equations.
12.1.16.24. MOMENTUM_Y_EQ(PHASE)
Table 12.77 Valid values
Solve Y-momentum equations.
12.1.16.25. MOMENTUM_Z_EQ(PHASE)
Table 12.78 Valid values
Solve Z-momentum equations.
12.1.16.26. MU_GMAX
12.1.16.27. NICE_DT
Flag to use nice time step value.
12.1.16.28. NSCALAR
to solve.
12.1.16.29. OMEGA_UNIT
Angular velocity unit. This is only meant to be used for granular DEM, CGP, SQP or GSP models to move STL files or group of particles. Example: OMEGA_UNIT = ‘REV/S’ means the angular velocity is expressed in revolutions per second.
Table 12.79 Valid values
RAD/S
Radian per second
DEG/S
Degree per second
REV/S
Revolution per second
RAD/MIN
Radian per minute
DEG/MIN
Degree per minute
REV/MIN
Revolution per minute
12.1.16.30. OPTFLAG1
Use NREL-CU optimization routines?.
12.1.16.31. PERSISTENT_MODE
Table 12.80 Valid values
Abort run when DT < DT_MIN.
12.1.16.32. PHASE4SCALAR(SCALAR EQUATION)
12.1.16.33. PPO
Flag to run the preprocessing (mesh generation) only and exit.
12.1.16.34. PROJECT_VERSION
12.1.16.35. REF_LENGTH_DG
12.1.16.36. RUN_NAME
Required
Name used to create output files. Limited to 60 characters. The name should generate legal file names after appending extensions. Ex: Given the input, RUN_NAME = “bub01”, MFIX will generate the output files: BUB01.LOG, BUB01.OUT, BUB01.RES, etc.
12.1.16.37. RUN_TYPE
Required
Type of run.
Table 12.81 Valid values
new
RESTART_1
RESTART_2
12.1.16.38. SPECIES_EQ(PHASE)
Table 12.82 Valid values
Solve species equations.
12.1.16.39. SPHERICITY_DG
12.1.16.40. SUBGRID_TYPE
Subgrid models.
Table 12.83 Valid values
Igci
Milioli
12.1.16.41. SUBGRID_WALL
Table 12.84 Valid values
12.1.16.42. TIME
12.1.16.43. TSTOP
Simulation stop time.
12.1.16.44. TURBULENCE_MODEL
Table 12.85 Valid values
No turbulence model.
MIXING_LENGTH
K_EPSILON
12.1.16.45. UNITS
Required
Table 12.86 Valid values
SI
cgs
