12.1.5. Discrete element model (DEM)¶
12.1.5.1. Discrete Element - Common¶
12.1.5.1.1. DES_DIFFUSE_WIDTH¶
The DES diffusion equation is listed as equation type 10 in the Numerical parameters section.
12.1.5.1.2. DES_EPG_CLIP¶
12.1.5.1.3. DES_EXPLICITLY_COUPLED¶
12.1.5.1.4. DES_INTERP_MEAN_FIELDS¶
12.1.5.1.5. DES_INTERP_ON¶
12.1.5.1.6. DES_INTERP_SCHEME¶
Do not use interpolation. |
Interpolate to/from a particle’s position using the corners (nodes) of the fluid cells. This was the default behavior prior to version 2015-1. See Garg et al. (2012) Documentation of the open-source MFiX-DEM software for gas-solids flows. |
Divided particle volume method: Information is interpolated to/from a particle’s position using a square filter of size DES_INTERP_WIDTH. |
Linear interpolation: Hat functions are used to distribute particle information. PIC only. |
Divided particle volume method using satellites. |
12.1.5.1.7. DES_INTERP_WIDTH¶
12.1.5.1.8. DES_INTG_METHOD¶
Time stepping scheme. Note that DEM solids species mass fraction always use firt-order Euler scheme regardless of this setting.
First-order Euler scheme. |
Second-order ADAMS_BASHFORTH scheme. (DEM only) |
12.1.5.1.9. DES_ONEWAY_COUPLED¶
Run one-way coupled simulations [default .FALSE.]. If set, the fluid does not see the particles in terms of drag force. The effect of particle volume is still felt by the fluid through non-unity voidage values.
12.1.5.1.10. DESGRIDSEARCH_IMAX¶
12.1.5.1.11. DESGRIDSEARCH_JMAX¶
12.1.5.1.12. DESGRIDSEARCH_KMAX¶
12.1.5.1.13. GENER_PART_CONFIG¶
Generate particle configuration based on the initial condition parameters. Data provided in the particle input file, if present, is ignored. |
Particle position and velocity data are provided in the particle input file. A runtime error occurs if this file is not provided. |
12.1.5.1.14. PARTICLES¶
Number of particles to be read in from the particle input file. This value is ignored when using automatic particle generation. If unset, read all particles from file. A simulation with a mass inflow BC can start without solids by setting PARTICLES = 0.
12.1.5.2. Discrete Element Model¶
12.1.5.2.1. ASPERITIES¶
12.1.5.2.2. DES_BUFF_RESIZE_FACTOR¶
12.1.5.2.3. DES_COLL_MODEL¶
The Hertzian model. Requires: DES_ET_INPUT, DES_ET_WALL_INPUT, E_YOUNG, EW_YOUNG, V_POISSON, VW_POISSON. |
12.1.5.2.4. DES_CONV_CORR¶
12.1.5.2.5. DES_EM(PHASE)¶
Emissivity of solids phase.
12.1.5.2.6. DES_EN_INPUT(INDEX)¶
12.1.5.2.7. DES_EN_WALL_INPUT(INDEX)¶
\(1 \le Index \le MMAX\)
12.1.5.2.8. DES_ET_INPUT(INDEX)¶
12.1.5.2.9. DES_ET_WALL_INPUT(INDEX)¶
12.1.5.2.10. DES_ETAT_FAC¶
12.1.5.2.11. DES_ETAT_W_FAC¶
12.1.5.2.12. DES_MIN_COND_DIST¶
12.1.5.2.13. DES_NEIGHBOR_SEARCH¶
12.1.5.2.14. DLB_DT¶
12.1.5.2.15. DLB_EGW¶
12.1.5.2.16. DTSOLID¶
Solids time step (s). If this value is left blank (UNDEFINED), then it will be automatically computed based on particle properties, and DTSOLID_FACTOR.
12.1.5.2.17. DTSOLID_FACTOR¶
Ratio between the collision time and the solids time step (default value is 50). Minimum value is 10.0. It is highly recommended to keep the default value.
12.1.5.2.18. DTSOLID_UPDATE_DT¶
12.1.5.2.19. E_YOUNG(PHASE)¶
12.1.5.2.20. E_YOUNG_ACTUAL(PHASE)¶
12.1.5.2.21. EW_YOUNG¶
12.1.5.2.22. EW_YOUNG_ACTUAL¶
12.1.5.2.23. FACTOR_RLM¶
12.1.5.2.24. FLPC¶
12.1.5.2.25. HAMAKER_CONSTANT¶
12.1.5.2.26. KN¶
12.1.5.2.27. KN_W¶
12.1.5.2.28. KT_FAC¶
12.1.5.2.29. KT_W_FAC¶
12.1.5.2.30. MEW¶
12.1.5.2.31. MEW_R¶
12.1.5.2.32. MEW_RW¶
12.1.5.2.33. MEW_W¶
12.1.5.2.34. MINIMIZE_DES_FACET_LIST¶
12.1.5.2.35. NEIGHBOR_SEARCH_N¶
12.1.5.2.36. NEIGHBOR_SEARCH_RAD_RATIO¶
12.1.5.2.37. NFACTOR¶
12.1.5.2.38. REMOVE_ROGUE_PARTICLES¶
12.1.5.2.39. USE_COHESION¶
12.1.5.2.40. USE_VDH_DEM_MODEL¶
12.1.5.2.41. V_POISSON(PHASE)¶
12.1.5.2.42. V_POISSON_ACTUAL(PHASE)¶
12.1.5.2.43. VAN_DER_WAALS¶
12.1.5.2.44. VDW_INNER_CUTOFF¶
12.1.5.2.45. VDW_OUTER_CUTOFF¶
12.1.5.2.46. VW_POISSON¶
12.1.5.2.47. VW_POISSON_ACTUAL¶
12.1.5.2.48. WALL_HAMAKER_CONSTANT¶
12.1.5.2.49. WALL_VDW_INNER_CUTOFF¶
12.1.5.2.50. WALL_VDW_OUTER_CUTOFF¶
12.1.5.3. Particles in Cell¶
12.1.5.3.1. FRIC_EXP_PIC¶
12.1.5.3.2. FRIC_NON_SING_FAC¶
12.1.5.3.3. MPPIC_COEFF_EN1¶
12.1.5.3.4. MPPIC_COEFF_EN_WALL¶
12.1.5.3.5. MPPIC_COEFF_ET_WALL¶
12.1.5.3.6. MPPIC_VELFAC_COEFF¶
12.1.5.3.7. PIC_CD_E¶
12.1.5.3.8. PIC_CFL¶
12.1.5.3.9. PIC_CFL_CONTROL¶
12.1.5.3.10. PIC_CFL_PARCEL_FRACTION¶
12.1.5.3.11. PIC_COLLISION_DAMPING¶
12.1.5.3.12. PSFAC_FRIC_PIC¶
