12.1.3. Cartesian grid
12.1.3.1. ADJUST_PROC_DOMAIN_SIZE
12.1.3.2. ALPHA_MAX
12.1.3.3. BAR_CHAR
Character used to create the progress bar.
12.1.3.4. BAR_RESOLUTION
12.1.3.5. BAR_WIDTH
12.1.3.6. BC_ID_Q(QUADRIC ID)
  • \(1 \le Quadric ID \le 500\)
Boundary condition flag.
12.1.3.7. BEND_R1(QUADRIC ID)
12.1.3.8. BEND_R2(QUADRIC ID)
Bend Radius 2 (used when QUADRIC_FORM = BEND*), BEND_R1>BEND_R2.
12.1.3.9. BEND_THETA1(QUADRIC ID)
12.1.3.10. BEND_THETA2(QUADRIC ID)
12.1.3.11. C2C_R1(QUADRIC ID)
12.1.3.12. C2C_R2(QUADRIC ID)
12.1.3.13. C2C_Y1(QUADRIC ID)
12.1.3.14. C2C_Y2(QUADRIC ID)
12.1.3.15. CAD_PROPAGATE_ORDER
Table 12.4 Valid values
Propagation occurs in unique cell index order, from IJK=IJKSTART3 to IJKEND3, one neighbor at a time (West, East, South, North, Bottom, Top)
ijk
Propagation occurs in the I, followed by J, and K directions
jki
Propagation occurs in the J, followed by K, and I directions
kij
Propagation occurs in the K, followed by I, and J directions
12.1.3.16. CARTESIAN_GRID
Table 12.5 Valid values
Do not use Cartesian grid cut cell technique.
Use Cartesian grid cut cell technique.
12.1.3.17. CG_SAFE_MODE
Run code in safe mode.
Table 12.6 Valid values
Performs initial preprocessing but use all original MFiX subroutines during flow solution (using only cell volumes and areas of cut cells).
Runs the code with modified subroutines for cut cell treatment.
12.1.3.18. CG_UR_FAC
12.1.3.19. CLIP_XMAX(QUADRIC ID)
12.1.3.20. CLIP_XMIN(QUADRIC ID)
12.1.3.21. CLIP_YMAX(QUADRIC ID)
12.1.3.22. CLIP_YMIN(QUADRIC ID)
12.1.3.23. CLIP_ZMAX(QUADRIC ID)
12.1.3.24. CLIP_ZMIN(QUADRIC ID)
12.1.3.25. DIM_FACETS_PER_CELL
Maximum number of STL facets per cell.
12.1.3.26. DQUADRIC(QUADRIC ID)
12.1.3.27. DWALL_BRUTE_FORCE
Brute force calculation of wall distance.
12.1.3.28. F_DASHBOARD
12.1.3.29. FAC_DIM_MAX_CUT_CELL
12.1.3.30. FLIP_STL_NORMALS(BC)
  • \(1 \le BC \le 500\)
Option to flip STL facet normals. The index corresponds to the BC ID the STL file is applied to.
Table 12.7 Valid values
.True.
Flip normals
.False.
Do not flip normals
12.1.3.31. FLUID_IN_CLIPPED_REGION(QUADRIC ID)
Table 12.8 Valid values
Remove cells from computational domain.
Treat cells as fluid cells.
12.1.3.32. GROUP_Q(GROUP ID, QUADRIC ID)
  • \(1 \le Group ID \le DIM{\_}GROUP\)
12.1.3.33. GROUP_RELATION(GROUP ID)
Table 12.9 Valid values
OR
A point belongs to the computational domain if at least one of f(x,y,z) among all quadrics is negative.
AND
A point belongs to the computational domain if all of f(x,y,z) among all quadrics are negative.
PIECEWISE
When quadrics intersect along planes that are perpendicular to either the x, y, or z-axis, quadrics can be smoothly combined in a piecewise manner.
12.1.3.34. GROUP_SIZE(GROUP ID)
12.1.3.35. HALF_ANGLE(QUADRIC ID)
12.1.3.36. ITERMAX_INT
12.1.3.37. LAMBDA_X(QUADRIC ID)
12.1.3.38. LAMBDA_Y(QUADRIC ID)
12.1.3.39. LAMBDA_Z(QUADRIC ID)
12.1.3.40. MINIMIZE_SEND_RECV
12.1.3.41. N_GROUP
Number of group(s) of quadrics (<=50).
12.1.3.42. N_QUADRIC
12.1.3.43. N_USR_DEF
Number of user-defined functions (currently limited to 0 or 1). If set to 1, the geometry is defined in the user subroutine eval_usr_fct.f.
Table 12.10 Valid values
Do not use user-defined function
Use one user-defined function
12.1.3.44. N_X(QUADRIC ID)
12.1.3.45. N_Y(QUADRIC ID)
12.1.3.46. N_Z(QUADRIC ID)
12.1.3.47. NODESI_REPORT
12.1.3.48. NODESJ_REPORT
12.1.3.49. NODESK_REPORT
12.1.3.50. OUT_MSH_VALUE
Defines value of f outside of the .msh geometry. a value of 1.0 means the domain outside of the .msh geometry is excluded from computation, i.e., an internal flow is computed.
Table 12.11 Valid values
-1.0
model an external flow
1.0
model an internal flow
12.1.3.51. OUT_STL_VALUE
Defines value of F_STL outside of the STL geometry. A value of 1.0 means the domain outside of the STL geometry is excluded from computation, i.e., an internal flow is computed. Note: This depends on the direction of the facet normal vectors.
Table 12.12 Valid values
-1.0
1.0
12.1.3.52. PG_OPTION
Table 12.13 Valid values
Use maximum of (east/west), (north/south), and (top/bottom) pairs of velocity cells.
Use both (east/west), (north/south), and (top/bottom) areas of velocity cells.
Use east, north and top areas of pressure cell (same as standard cells).
12.1.3.53. PIECE_XMAX(QUADRIC ID)
12.1.3.54. PIECE_XMIN(QUADRIC ID)
12.1.3.55. PIECE_YMAX(QUADRIC ID)
12.1.3.56. PIECE_YMIN(QUADRIC ID)
12.1.3.57. PIECE_ZMAX(QUADRIC ID)
12.1.3.58. PIECE_ZMIN(QUADRIC ID)
12.1.3.61. QUADRIC_FORM(QUADRIC ID)
Table 12.14 Valid values
normal
Use normal form, as defined in equation (1). The LAMDBAs and D must be defined
plane
Plane. Needs to define N_X,N_Y,N_Z (unit normal vector pointing away from fluid cells).
x_cyl_int
Cylinder aligned with x-axis, internal flow. Needs to define RADIUS(QID).
x_cyl_ext
Cylinder aligned with x-axis, external flow. Needs to define RADIUS(QID).
y_cyl_int
Cylinder aligned with y-axis, internal flow. Needs to define RADIUS(QID).
y_cyl_ext
Cylinder aligned with y-axis, external flow. Needs to define RADIUS(QID).
z_cyl_int
Cylinder aligned with z-axis, internal flow. Needs to define RADIUS(QID).
z_cyl_ext
Cylinder aligned with z-axis, external flow. Needs to define RADIUS(QID).
x_cone
Cone aligned with x-axis, internal flow. Needs to define HALF_ANGLE(QID).
y_cone
Cone aligned with y-axis, internal flow. Needs to define HALF_ANGLE(QID).
z_cone
Cone aligned with z-axis, internal flow. Needs to define HALF_ANGLE(QID).
sphere_int
Sphere, internal flow. Needs to define RADIUS(QID).
sphere_ext
Sphere, external flow. Needs to define RADIUS(QID).
C2C
Cylinder-to-cylinder conical junction, internal flow. Needs to be defined between two cylinders.
Torus_int
Torus, internal flow. Needs to define TORUS_R1(QID) and TORUS_R2(QID).A torus is not a quadric surface but is defined as a basic shape.
Torus_ext
Torus, external flow. Needs to define TORUS_R1(QID) and TORUS_R2(QID).
Y_UCOIL_EXT
Pair of parallel cylinders (y-direction), capped at both ends by a cylinder at 90 degree angle to create a U-shaped coil. Needs UCOIL_R1, UCOIL_R2, UCOIL_Y1, UCOIL_Y2.
XY_BEND_INT
Bend between two cylinders in the XY plane, Needs BEND_R1,BEND_R2,BEND_THETA1,BEND_THETA2.
Y_C2C_INT
connects two vertical cylinders by a conical section. Needs C2C_R1,C2C_R2,C2C_Y1,C2C_Y2.
REACTOR1
Reactor, made of two vertical cylinders, connected by a conical section. Each cylinder is rounded and closed by a conical cap. Needs REACTOR1_R1,REACTOR1_R2,REACTOR1_Y1,REACTOR1_Y2, REACTOR1_YR1,REACTOR1_YR2,REACTOR1_RR1,REACTOR1_RR2, REACTOR1_THETA1,REACTOR1_THETA2.
12.1.3.62. QUADRIC_SCALE
12.1.3.63. RADIUS(QUADRIC ID)
12.1.3.64. RAY_DIR
Ray direction when propagating CAD value
12.1.3.65. RE_INDEXING
12.1.3.66. REACTOR1_R1(QUADRIC ID)
12.1.3.67. REACTOR1_R2(QUADRIC ID)
12.1.3.68. REACTOR1_RR1(QUADRIC ID)
12.1.3.69. REACTOR1_RR2(QUADRIC ID)
12.1.3.70. REACTOR1_THETA1(QUADRIC ID)
12.1.3.71. REACTOR1_THETA2(QUADRIC ID)
12.1.3.72. REACTOR1_Y1(QUADRIC ID)
12.1.3.73. REACTOR1_Y2(QUADRIC ID)
12.1.3.74. REACTOR1_YR1(QUADRIC ID)
12.1.3.75. REACTOR1_YR2(QUADRIC ID)
12.1.3.76. RELATION_WITH_PREVIOUS(GROUP ID)
Table 12.15 Valid values
OR
A point belongs to the computational domain if f-value for the current group or f-value for the combination of previous groups is negative.
AND
A point belongs to the computational domain if f-value for the current group and f-value for the combination of previous groups is negative.
12.1.3.77. REPORT_BEST_DOMAIN_SIZE
12.1.3.78. SCALE_MSH
12.1.3.79. SCALE_STL
12.1.3.80. SET_CORNER_CELLS
Table 12.16 Valid values
Some cut cells may be treated as corner cells.
Do not treat cut cells as corner cells.
12.1.3.81. STL_BC_ID
Boundary condition flag for the STL geometry
12.1.3.82. STL_NB_ANGLE
Angle (degrees) to detect if two STL facets are nearly aligned. This is used to ignore edge collision in DEM simulations. Particle-edge collision will be ignored if the angle between two facets is smaller than STL_NB_ANGLE.
12.1.3.83. STL_SMALL_ANGLE
Smallest angle accepted for valid STL triangles (in degrees). Triangles having an angle smaller that this value will be ignored.
12.1.3.84. T_X(QUADRIC ID)
Translation in x-direction.
12.1.3.85. T_Y(QUADRIC ID)
Translation in y-direction.
12.1.3.86. T_Z(QUADRIC ID)
Translation in z-direction.
12.1.3.87. THETA_X(QUADRIC ID)
12.1.3.88. THETA_Y(QUADRIC ID)
12.1.3.89. THETA_Z(QUADRIC ID)
12.1.3.90. TOL_DELH
Tolerance used to limit acceptable values of normal distance to the wall (expressed as a fraction of cell diagonal, between 0.0 and 1.0).
12.1.3.91. TOL_F
12.1.3.92. TOL_MERGE
Tolerance used to remove duplicate nodes (expressed as a fraction of cell diagonal, between 0.0 and 1.0).
12.1.3.93. TOL_MSH
12.1.3.94. TOL_POLY
12.1.3.95. TOL_SMALL_AREA
Tolerance used to detect small faces (expressed as a fraction of original face area, between 0.0 and 1.0).
12.1.3.96. TOL_SMALL_CELL
Tolerance used to detect small cells (expressed as a fraction of cell volume, between 0.0 and 1.0).
12.1.3.97. TOL_SNAP(DIRECTION)
  • \(1 \le Direction \le 3\)
Tolerance used to snap an intersection point onto an existing cell corner (expressed as a fraction of edge length, between 0.0 and 0.5). For stretched grids, three values can be entered in the x, y and z directions.
12.1.3.98. TOL_STL
12.1.3.99. TOL_STL_DP
12.1.3.100. TORUS_R1(QUADRIC ID)
12.1.3.101. TORUS_R2(QUADRIC ID)
12.1.3.102. TX_MSH
12.1.3.103. TX_STL
12.1.3.104. TY_MSH
12.1.3.105. TY_STL
12.1.3.106. TZ_MSH
12.1.3.107. TZ_STL
12.1.3.108. UCOIL_R1(QUADRIC ID)
12.1.3.109. UCOIL_R2(QUADRIC ID)
12.1.3.110. UCOIL_Y1(QUADRIC ID)
12.1.3.111. UCOIL_Y2(QUADRIC ID)
12.1.3.112. USE_MSH
Table 12.17 Valid values
Do not use .msh file.
Read geometry (for 3d geometry only) from geometry.msh.
12.1.3.113. USE_POLYGON
Table 12.18 Valid values
Do not use polygons.
Read polygon data (for 2d geometry only) from poly.dat.
12.1.3.114. USE_STL
Table 12.19 Valid values
Do not use STL file.
Read triangulated geometry (for 3d geometry only) from geometry_####.stl.
12.1.3.115. WRITE_DASHBOARD
