12.1.6. Gas phase¶
12.1.6.1. C_PG0¶
12.1.6.2. DABG(SPECIES, SPECIES)¶
\(1 \le Species \le 100\)
Set constant binary diffusion coefficients if known [m^2/s in SI]
12.1.6.3. DIF_COEFF_KT¶
Compute diffusion coefficients from kinetic theory.
Use constant diffusion coefficients. Diffusion data can be obtained from:
Compute diffusion coefficients from kinetic theory. Parameters in Lennard-Jones intermolecular potential model can be obtained from:
12.1.6.4. DIF_G0¶
12.1.6.5. DIF_THERMAL¶
Include thermal diffusion in multicomponent diffusion model.
Compute thermal diffusion. |
Ignore effects of thermal diffusion. |
12.1.6.6. HB_GAMA_C¶
Strain rate cutoff [1/s] in Herschel-Bulkley viscosity law.
12.1.6.7. HB_K0¶
Consistency factor [Pa.s^n] in Herschel-Bulkley viscosity law.
12.1.6.8. HB_N¶
Power law index (dimensionless) in Herschel-Bulkley viscosity law.
0 < HB_n < 1 : Shear thinning fluid
HB_n = 1 : Bingham fluid
HB_n > 1 : Shear thickening fluid
12.1.6.9. HB_TAU0¶
Bingham yield stress [Pa] in Herschel-Bulkley viscosity law.
12.1.6.10. K_G0¶
12.1.6.11. LJEPS(SPECIES)¶
Epsilon/k coefficient in Lennard-Jones potential [in Kelvin].
12.1.6.12. LJSIG(SPECIES)¶
Sigma coefficient in Lennard-Jones potential [in Angstrom].
12.1.6.13. MU_G0¶
Specified constant gas viscosity [Pa.s in SI].
12.1.6.14. MU_G_MODEL¶
Gas viscosity model (default is Sutherland’s law).
Constant viscosity |
Sutherland’s law |
Herschel-Bulkley (non-Newtonian) model |
User-defined function |
12.1.6.15. MULTI_COMPONENT_DIFFUSION¶
Solve the multicomponent diffusion model.
Include multicomponent diffusion model in species equation. |
Do not include multicomponent diffusion model. |
12.1.6.16. MW_AVG¶
12.1.6.17. MW_G(SPECIES)¶
12.1.6.18. NMAX_G¶
12.1.6.19. RO_G0¶
12.1.6.20. SL_MUREF¶
Reference gas viscosity [Pa.s in SI] in the Sutherland’s law.
12.1.6.21. SL_S¶
Sutherland constant [K] in the Sutherland’s law.
12.1.6.22. SL_TREF¶
Reference temperature [K] in the Sutherland’s law.
12.1.6.23. SPECIES_ALIAS_G(SPECIES)¶
12.1.6.24. SPECIES_G(SPECIES)¶
