3.4. Three-dimensional single-phase flow over a sphere¶
This tutorial shows how to create a three dimensional single-phase flow over a sphere.
60 cm 20 cm x 20 cm |
30 x 10 x 10 |
1 m/s |
3.4.1. Create a new project¶
3.4.2. Select model parameters¶
On the Model
fieldSelect “Single-phase” in the
drop-down menu.
3.4.3. Enter the geometry¶
pane enter the domain extents:
60/100
meters for the maximum x value20/100
meters for the maximum y value20/100
10/100
for the center X position10/100
for the center Y position10/100
for the center Z position
5/100
for the radius.
3.4.4. Enter the mesh¶
pane, Background
for the y cell valueEnter
for the z cell value
3.4.5. Create regions for initial and boundary condition specification¶
Select the Regions
(all) button to create a region that encompasses the entire domain
name
such as “sphere”Check the
Select facets (STL)
checkbox to turn the region into a STL region. The facets of the sphere should now be selected.
field (“slice”)Enter
zmax/2
in both theFrom Z
andTo Z
fields to move the region to the center of the domain
3.4.6. Create Initial conditions¶
Initial conditions
paneSelect the already populated “Background” from the region list. This will initialize the entire flow field with air.
101325
Pa in thePressure (optional)
3.4.7. Create Boundary conditions¶
the sphere by:
Select region
combo-boxSelect the “sphere” region and click
Add a mass inflow boundary condition by:
Select region
combo-boxSelect the “inlet” region and click
X-axial velocity
field of1.0
m/s
Select region
3.4.8. Select output options¶
checkbox
sub-paneSelect the “slice” region from the list to save cell data at a slice through the domain
to “0.01” secondsSelect the
Pressure
,Velocity vector
,Velocity x-component
,Velocity y-component
, andVelocity z-component
checkboxes on theFluid
sub-sub-pane
3.4.9. Change run parameters¶
Change
Stop time step
to2.0
secondsChange
to1e-2
secondsChange
to1e-2
seconds
3.4.10. Run the project¶
Run Solver
dialog, select the executableClick the
Run
3.4.11. View results¶
3D view
