3.11. Hydrogen oxidation in a batch reactor using CHEMKIN mechanism¶
This tutorial shows how to import thermodynamic information of species and kinetic mechanism from CHEMKIN into MFiX. A batch reactor in a single cell is simulated in this tutorial. The mechanism for the oxidiation of hydrogen from Conaire et al. [1] is applied.
3.11.1. Load the project into MFiX¶
The basic model has been set up in the input file, “hydrogen_oxidation.mfx”.
On the main menu select
.Open the project
hydrogen oxidation with CHEMKIN mechanism, step by step
Choose the location for your working directory and click
The main purpose of this tutorial is to show how to use CHEMKIN mechanism in MFiX. For more details about the model setup, please refer to other tutorials.
3.11.2. Generate mesh¶
On the Mesher
Generate
to generate the meshClick
Accept
to accept the mesh, and switch to the Modeler tab (bottom left of GUI).
3.11.3. Import species for fluid phase¶
On the Fluid
Load from file (CHEMKIN format)
inSource
of the popup window
Choose file
, choose “thermodynamicInfo.txt” in the popup window, and clickOpen
After importing the file, the species defined in the file will show in the window.
Select all the species (click on first species “AR” and drag down) and click
import from database
to import all species. ClickDone
Users have the flexibility to select the required species for their case from the provided list. If a species is not defined in the CHEMKIN file, users can import it from the built-in Burcat database or an external Burcat file as well.
For reacting cases, constant specific heat capacity is not allowed. Change it to “Mixture” in “Properties”.
3.11.4. Create Initial and Boundary conditions¶
pane, set the following conditions as the initial conditions.
Initial Value |
Volume Fraction |
1.0 |
Temperature |
800 K |
Pressure |
101325 Ps |
U-Velocity |
0.0 m/s |
V-Velocity |
0.0 m/s |
W-Velocity |
0.0 m/s |
Composition |
H2: 0.1, O2: 0.8, N2: 0.1, OH: 0.0, TestSpecies: 0.0 |
pane, No-Slip and adiabatic walls have been setup.
3.11.5. Import kinetic mechanism¶
On the Chemistry
pane, Options
Check the
Enable Arrhenius model for fluid phase reactions
checkboxChange the
Minimum mass fraction for reactions
forFluid reactions
to 0 to consider all species with mass fraction larger than 0 in the reactionsCheck the
Enable stiff chemistry solver
checkboxChange the
Absolute tolerance
,Relative tolerance
andMinimum reaction rate
in stiff solver to be 1e-09, 1e-08 and 1e-20.
Users can change the minimum mass fraction for reactions and the parameters for stiff solver based on the accuracy requirement of their cases.
On the Chemistry
pane, Reactions
Load reaction definitions from text file
and selectChemkin format
Select the mechanism file “chemkin_mechanism.CKI” in the popup window. Click
Open
Then all the reactions with all the information will be imported
3.11.6. Setup output, monitor and run parameters¶
The output, monitor and run parameters have been setup. Users can modify them based on their own requirement.
To check the change of species, we need to save the species into the output/monitor files.
sub-pane. An output has been setup.In the
Fluid
ofSelect cell data to write
at the bottom of GUI, select the checkboxes for species inMass fraction
On the Monitors
An monitor has been setup with the gas temperature saved every 0.001s.
In the
Fluid
at the bottom of GUI, select the checkboxes for species H2 and O2 inMass fraction
3.11.7. Run the project¶
3.11.8. View results¶
This tutorial simulates the oxidation of H2 in a batch reactor. Users should expect to see consumption of H2 and O2 and a temperature increase from the exothermic reaction.
Monitors
to view the results.On the
Monitors
results tab, the visibility of the variables can be controlled with the menu under the plot.
Hide the gas temperature by unclick the
for variable t_g. The following plot with the transient changes of the mass fraction of H2 and O2 will be shown.
Hide the gas species by unclick the
for variables x_g_H2 and x_g_O2. The following plot with the transient change of the gas temperature will be shown.
