6.3. Running Custom Interactive Solver¶
First build a custom solver.
6.3.1. Running custom solver from GUI¶
6.3.2. Running custom solver from command line¶
As an example, the tfm/silane_pyrolysis_2d tutorial has UDFs and will not run with the
default solver.
After building the solver, on a Linux or Mac system, run the custom solver with the command:
~/projectdir> ./mfixsolver -f SP2D.mfx
Use ./ in front of mfixsolver to use the solver in the project directory, not the default solver in your PATH.
On Windows, run the custom solver in the project directory with:
C:\projectdir > mfixsolver -f SP2D.mfx
