When mfix solver was build, we can not change the geometry or mesh, or it will display the error *** 110 files that already exist.
In this case, we need to delete the build folder and rebuild it.
Hi Yuwanhei. I’ll take a look at this issue. But I’m having trouble finding the error message you are referring to. Can you give me the exact error message? Is it this one, from des/generate_particles_mod.f ?
Warning 1100: ',A,' already exists and will be overwritten.')
If that’s the case, it should be a non-fatal error. If it’s a different one, please let me know.
- Charles
Hi Charles,
Sorry to reply so late.
I did not expect one answer for this topic so I did not follow it.
The problem happens on MFIX-20.4.2.
Sometimes when I want to change the value of a parameter, It reminds me that this value is not integer althrough the value is fine in physical.
Then when i compile and run it will show the message as posted above.
I happend to find that the case can run when i delete all compile files and rebulid it.
Sorry i can not provide the screenshot for now. When someday it reappreases, i will update this post.
Regards
Yuanhe
