Hi,everyone
I have a problem with 3D view.The first time I run my case, the 3D view works fine.However, when I re-run after changing the mesh size, the 3D view doesn’t display properly.Could you please tell me how to solve this problem?
Thank you!
Can you provide the case file? Also did you delete any files outside of MFIX?
I’m very sorry to reply you so late.I solved this problem by increasing the thickness on the z axis.± 0.1, 0.01, 0.001, or even 1e-07.
