Hello, everyone. I noticed that the drag force formula of Gidaspow. There is a εs and a εm on the molecular. However, I didn’t find them in the drag_gs as following picture. So I wanna know if someone know the reason about it.
As far as I know, beta is equal to DgA*EPs.
You can see other formulas are also divided by EPs.
When F_gs is calculated, EPs is considered.
Thanks a lot firstly. Now, I wanna create a new drag force model. So as you mean, I should let beta divide by EPs also, is that right?
I think so. If you apply a new usr drag model including EPs, then it will be applied twice.
yep, I agree with you. It makes a big deviation if I add eps on the formula. I’ll try it. Appreciate it for you again!
