Dear sir, as far as I know, when the energy equation is activated, the DES_INTERP_ON and DES_EXPLICITLY_COUPLED the can not be used. Which means we cannot use the interpolation of field quantities (e.g. Temperature) to a particle’s position. The DES_EXPLICITLY_COUPLED and DES_INTERP_ON algorithm are limited to hydrodynamic simulations at present, am I right?
But I was wondering why? Is it because whether interpolation (as well as explicit coupling) or not is not that important in temperature and heat transfer or some reason else?
And how can I fix it, if I want to activate the DES_INTERP_ON and DES_EXPLICITLY_COUPLED in heat transfer calculation?
I am looking forward to your reply, and thanks a lot in advance!
Yours, Naval
