Hello,!
I added a new reaction in the CO2 absorption case, named Reaction_1, and defined the new reaction rate as a constant in USR_rates.f, in an attempt to generate solid2, but actually it did not generated.
Actually, we are trying to simulate the gas-liquid-solid flow based on this CO2 absorption case, in which the liquid and solid phase is described as solid 1 and solid2, both of them are solved as one phase of TFM. In this tutorial case, the existence of the reactor internals are reflected by the solid2. Thus, we want to use this framework to study a gas-liquid-solid system, in which the fluid phase breaks to gas and solid phase.
What’s the reason and What should I do?
Thanks!
Absorption_column_2d.zip (36.9 MB)
