Error: Solver crash! The MFiX solver has terminated unexpectedly Error information: float divide by zero in __solve_k_epsilon_eq_mod_MOD_source_k_epsilon_bc at solve_k_epsilon_eq.f:375
Hi @ma3498944 and welcome to the MFiX forum. Thanks for the bug report.
First off -
The expression 0.42D+0 is a Fortran double-precision constant - the D signifies double, and the +0 is the exponent. This is just 0.42. And the code has: 0.42D+0 * DELH_Scalar(IJK)
so DELH_Scalar is not being multiplied by 0, it’s being multiplied by 0.42.
In modern Fortran it is not necessary to write 0.42D+0, one can just write 0.42 but older versions of Fortran would carry out computations in single-precision unless double-precision constants were used, so many authors prefer to continue to write constants in this way.
Second -
please go to the main menu in MFiX and select “Submit bug report”, this will generate a ZIP file which you can upload here, and we can look further into the problem.
Hi, @ma3498944 , May I know how you solved the problem ?
I have changed the
B_M(IJK,M) =-((0.09D+0)**0.75K_Turb_G(IJK)**1.5)/&
(0.42D+0 * DELH_Scalar(IJK))
to
(0.42 * DELH_Scalar(IJK)),
but it still shows the error.
