Hi there,
I would like to simulate the particles falling down case, but finally there is an error that I could not solve. Which says: Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation. I run it in mfix-21.2, is there anything wrong with my settings? I checked through some similar questions posted before, but still could not get it fixed. Thank you for helping. The project files are attached. 2D_geometry_DEM.zip (6.4 KB)
I tried running this case in the latest MFiX version (22.4.3), which is always recommended, especially if you are getting errors.
Rather than a SIGFPE, I got this message:
Error 1110: Solids velocity for BC 2 is too low to satisfy DEM
inlet packing restrictions. Potential solutions:
> If the BC velocities (BC_U_s, BC_V_s, BC_W_s) are defined, specify
a larger value for the velocity normal to the flow plane.
> If MASSFLOW or VOLFLOW are defined, decrease the solids volume
fraction to increase solids velocity.
Max user-specified BC velocity: 0.20000
Minimum required solids Velocity: 0.24099
After changing the BC of mass inflow from -0.2m/s to 0.3 m/s, and also increasing the diameter of particles from 0.001 to 0.005, I managed to run it successfully with MFiX version 22.4.2. Should be fine for 22.4.3 also. Cheers.
