Dear Developer,
I am trying to implement particles cycling in the y-direction while the gas is not cycling. Dr. Jeff. gave me some valuable advice: use cyclic-BC and modify the code set_flags.f. I followed the advice and it works fine in serial mode, but in DMP parallel mode (i.e., NODESJ>1), set_flags.f doesn’t work resulting in both the gas and the particles are looped in the y-direction. I tried changing ‘J == JMAX2’ to ‘J == JMAX3’ and it still doesn’t do anything. Can you tell me why this is and which codes should be changed in DMP parallel mode?
Thanks for your help!
