also, as you probably noticed, when it crashed it printed the first png file but not the second. which is strange, because the second image is just a subset of the first image. same slice, subset of particles thresholded by phase. it has to be something in that threshold, likely at the mass inflow.
Thanks @wfullmer . Your run was using 72 MPI procs, mine was using 128, so that possibly explains the difference in the images. May I ask what was the reason for choosing 72? This case has 512 boxes so I thought it would be good to use a number that divides 512.
I also noticed that the s2/p2 messages are somehow buffered and don’t appear until the end. I’m hoping to fix that too, but that’s a separate problem.
I’m currently running some debug-mode jobs on Joule under gdb and hoping to catch a full stack trace with local variables, etc, as the Viskores team asked for. However these are running extremely slowly. What we’re trying to catch is the failing assert in Viskores:
ArrayPortalBasic.h:73:
Assertion `index < this->NumberOfValues' failed.
not the “s2/p2” message (which may or may not be related to the crash)
Will follow up when I get more info.
I just guessed that 6^3 grids was too small and used a larger size. Specifically, 8x8x16 because that fit on one node. This is why I asked if Yupeng set it up. As one of the Bernoulli’s said of Newton, I recognize the lion by his paw.
For the record, Will ran with
amr.max_grid_size_x = 8
amr.max_grid_size_y = 8
amr.max_grid_size_z = 16
so it’s not the same inputs file. Larger max_grid_size was one of my recommendations in a previous post. But I’m trying to debug the reported Ascent/Viskores issue which is triggered by Femi’s original 6x6x6 settings (whether or not those are good settings, it should not cause a crash).
Update on the Ascent crash. I’ve identified the problem and submitted a fix:
Ascent mishandles coincident or very-close (within merge threshold) particles. This would probably only happen in a PIC simulation.
This was interesting, I had a chance to learn a lot about the internals of Ascent and Viskores.
@oyedejifemi if you’re still trying to run this simulation, and don’t want to wait for Ascent to fix this, you can clone my repo at github.com/charlesgwaldman/ascent and check out the threshold-no-point-merge branch. Please let me know if this works for you. I’ve run your job to tstop=10 without errors.
