You may be able to use the pause/resume feature if you are running from the GUI. Start the simulation with FOUP, let is run for a while. The press the pause button
(between the play and stop buttons)
This will keep your job in the queue. You can change a few simulation parameters, like the simulation end time, bc inlet velocity. You can also change the discretization scheme. Go to Numerics> Discretization pane and change the scheme to Superbee. Save the file and press the play button to resume the simulation.
