I’m using the DEM method to model gas-solid flows. My geometry is shown below in the first picture, and I want to set the bottom of the internal as the pressure outlet, which is marked in the circle. In the region section, I used a plane to define this area, which is shown in the second picture. Then, I define this area as the pressure-outlet boundary condition. The running reports some errors shown in the last picture. I don’t find any boundary that overlaps with this one. Can you give me some suggestions about how to solve this problem?
.While, no matter how I changed the selecting box (red box in the above figure), 10 facets are chosen(Actually I only want to choose the two facets on the bottom). So I have to manually adjuste the file geometry_0008.stl to keep only two facets.
. If you are satisfy with that only gas leaves at BC(8), the code might work after some modifications. Another option is that you can open one or two small pressure outlets (PO) on the front or/and back (XY)plane.
Thank you so much for helping me test the case. I can accept that only gas leave the reactor from BC(8). Can you tell me how to modify the source programme? Thanks again.
I slightly modified several files, while it always diverged after about 20 time steps because the pressure equation can not converge. Thus try other options such as one or two small pressure outlets (PO) on the front or/and back (XY)plane. Other people may have better ideas to solve your problem.
Thanks so much!! Although it doesn’t work, can you tell me which file is modefied by you in the source programme? So I can know how to solve similar problems when I encounter similar problems in future.
