Bug GSP with DMP? Initial GSP orientations from particle_input.csv do not seem to be broadcast to other processes
Dear MFiX community,
I think I have come across a bug where the orientations stored in the particle_input.csv are not broadcast to other processes than the “first” when running the DMP solver. I have attached the .zip file with an example of this.
If I run this sim using DMP then all but the particles in the domain of the first processor have the “default” orientation instead of the orientation specified in the particle_input.csv file.
If I run the sim using single threaded or the SMP solver then they have all the correct orientations, indicating the problem is not with the particle_input.csv file.
I couldn’t find anything on the forum regarding this problem and thought that was odd but I have been unable to fix it. Has anyone else experienced this problem?
932_2026-03-31T094420.157658.zip (25.9 MB)
Note I am using MFiX 25.3 as the new 26.1 does not work on our cluster due to a bug related to “OSError: /lib64/libmvec.so.1: version `GLIBC_2.35’ not found” but I will not consider this a bug until the system administrator has confirmed its not a local problem we have.
Best Regards,
Simon
Hi Simon,
Thanks for testing it, I confirmed that it was a bug within the GSP implicit representation. There will be a fix if you can add the following line:
CALL bcast(found_quat, pe_io)
into line 2922 in mfix/model/des/read_particle_input.f, it will look like this at the end:
         ELSEIF(GSP_IMPLICIT) THEN
            CALL bcast(quat_start, PE_IO)
         ENDIF
Thanks for the extremely fast response.
I checked and it works.
Best Regards,
Simon
