Hello, I used the GSP solver to simulate cylindrical particle fluidization and found some problems (maybe a bug).
The simulation case is copied from this folder: mix-24.2.3/tutorials/gsp/fb_gsp.
I only changed the drag model (Gidaspow) and the inlet gas velocity in the Y direction (2 m/s, 4 m/s, and 6 m/s). The problem is that the cylinders cannot be fluidized at the inlet velocity of 2 m/s.
Actually, the domain and particle properties used in this case are almost the wood cylinders, like the following references, and the minimum fluidization velocity of these cylinders is less than 1 m/s. So, cylinders should be completely fluidized at 2 m/s.
References:
http://dx.doi.org/10.1016/j.powtec.2015.11.045
https://doi.org/10.1002/aic.17211.
fb_gsp_Ug_Cases.zip (125.1 KB)
