Can anyone advise me how to proceed with these procedures? I have anaconda packages, but I couldn’t find a command prompt to use. One more thing, what is the meaning of “source” here?
Thank you in advance!
There are two ways of installing MFIX; 1. Is directly using the command path automatically generated for your machine. 2. You download the entire source code to your nachine and then install it. This is what is meant from source.
So if you installed using the command line using approach 1, then you open MFIX from your working folder in the anaconda prompt. Then type the command “build mfixsolver postmfix”. If successfully installed you then type “postmfix” to run the module and follow the prompts thereafter for your particular needs.
