Dear Developer,
I have compiled a chemical rate UDF of Ca(OH)2 decomposition, but the calculation example has been calculating divergence. Could you help find the cause? The example has been uploaded.
test.zip (30.5 MB)
Please check the warning messages.
I’m seeing a large number of warnings about excessive inlet velocity.
Note, you can use TAB and arrow keys to easily scroll through the errors.
While you can try increasing MAX_INLET_VEL_FAC as suggested in the message, this kind of error is usually due to poor mesh quality. This is a fairly common type of error. Try searching the forum fo related post. Search results for 'max_inlet_vel_fac' - NETL Flow Science Software Support
Thank you very much!!
