can somebody help me??
C:\Users\LG\Documents>python -m pip install mfix-21.4.tar.gz
Processing c:\users\lg\documents\mfix-21.4.tar.gz
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing metadata (pyproject.toml) … done
Collecting matplotlib<4,>=3
Using cached matplotlib-3.5.1-cp310-cp310-win_amd64.whl (7.2 MB)
Collecting requests<3,>=2
Using cached requests-2.27.1-py2.py3-none-any.whl (63 kB)
Collecting Splipy<2,>=1
Using cached Splipy-1.5.7.tar.gz (212 kB)
Preparing metadata (setup.py) … error
ERROR: Command errored out with exit status 1:
command: ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\python.exe’ -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’“‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_8ed66e73ed2349d0876cd0099d00563e\setup.py’”’“‘; file=’”‘“‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_8ed66e73ed2349d0876cd0099d00563e\setup.py’”’“';f = getattr(tokenize, '”‘“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ egg_info --egg-base ‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-pip-egg-info-bwwv0mlm’
cwd: C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_8ed66e73ed2349d0876cd0099d00563e
Complete output (5 lines):
File “”, line 1, in
File “C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_8ed66e73ed2349d0876cd0099d00563e\setup.py”, line 5, in
import numpy as np
ModuleNotFoundError: No module named ‘numpy’
WARNING: Discarding https://files.pythonhosted.org/packages/34/e1/84f7326db642c38f0e34662fea7c282c53d0ba79211c24c60278da7e7612/Splipy-1.5.7.tar.gz#sha256=400931df9159adcc88e07731c256f1af9f8f4c96babb9a058e6dbad04afdda39 (from Links for splipy). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached Splipy-1.5.6.tar.gz (211 kB)
command: ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\python.exe’ -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’“‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_110a270edaa94bf6a27c0fcd15b29627\setup.py’”’“‘; file=’”‘“‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_110a270edaa94bf6a27c0fcd15b29627\setup.py’”’“';f = getattr(tokenize, '”‘“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ egg_info --egg-base ‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-pip-egg-info-lqp0u8w9’
cwd: C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_110a270edaa94bf6a27c0fcd15b29627
File “”, line 1, in
File “C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_110a270edaa94bf6a27c0fcd15b29627\setup.py”, line 5, in
import numpy as np
WARNING: Discarding https://files.pythonhosted.org/packages/67/96/f6b9ce5a8128463a844803008d8ef73aa006b3e2d6cf539395be2810af24/Splipy-1.5.6.tar.gz#sha256=6b204494fc7b4cc5c70d4ffa5db1cf20fd5326e23aa6493c743912b148b5ca22 (from Links for splipy). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached Splipy-1.5.3.tar.gz (211 kB)
command: ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\python.exe’ -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’“‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_f0236cfd44e943b084cef7cc62037b6b\setup.py’”’“‘; file=’”‘“‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_f0236cfd44e943b084cef7cc62037b6b\setup.py’”’“';f = getattr(tokenize, '”‘“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ egg_info --egg-base ‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-pip-egg-info-wjwv5wq1’
cwd: C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_f0236cfd44e943b084cef7cc62037b6b
File “”, line 1, in
File “C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_f0236cfd44e943b084cef7cc62037b6b\setup.py”, line 5, in
import numpy as np
WARNING: Discarding https://files.pythonhosted.org/packages/77/35/b82b10e0313e80cab27c0b252709e94cc9d03f93b6cc65971c8ea79332f6/Splipy-1.5.3.tar.gz#sha256=97567fd867e38aeae1ca27d95014259fa52308474ddc36edfdc1df4703b33975 (from Links for splipy). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached Splipy-1.5.2.tar.gz (211 kB)
command: ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\python.exe’ -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’“‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_8aa6674c018048f1a395749c271bebd4\setup.py’”’“‘; file=’”‘“‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_8aa6674c018048f1a395749c271bebd4\setup.py’”’“';f = getattr(tokenize, '”‘“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ egg_info --egg-base ‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-pip-egg-info-1nwmu2jj’
cwd: C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_8aa6674c018048f1a395749c271bebd4
File “”, line 1, in
File “C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\splipy_8aa6674c018048f1a395749c271bebd4\setup.py”, line 5, in
import numpy as np
WARNING: Discarding https://files.pythonhosted.org/packages/b9/34/97e60f58d5426de6d63fc3eb5b639937b11d92be07563e6b9dbe577bd3b1/Splipy-1.5.2.tar.gz#sha256=50456678b0908e8aa40b81810f2abcadf724226000aacf3a5dcae77f766adb80 (from Links for splipy). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Using cached Splipy-1.3.1-py2.py3-none-any.whl (117 kB)
Collecting ffmpeg-python
Using cached ffmpeg_python-0.2.0-py3-none-any.whl (25 kB)
Collecting pyyaml<6,>=5
Using cached PyYAML-5.4.1.tar.gz (175 kB)
Collecting numpy==1.19.3
Using cached numpy-1.19.3.zip (7.3 MB)
Preparing metadata (pyproject.toml) … error
command: ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\python.exe’ ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib\site-packages\pip_vendor\pep517\in_process_in_process.py’ prepare_metadata_for_build_wheel ‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\tmpgwf2bnvn’
cwd: C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\numpy_45b3cc41e623428693baaa43a0506bab
Complete output (204 lines):
setup.py:67: RuntimeWarning: NumPy 1.19.3 may not yet support Python 3.10.
warnings.warn(
Running from numpy source directory.
setup.py:480: UserWarning: Unrecognized setuptools command, proceeding with generating Cython sources and expanding templates
run_build = parse_setuppy_commands()
C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\numpy_45b3cc41e623428693baaa43a0506bab\tools\cythonize.py:67: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
from distutils.version import LooseVersion
Processing numpy/random_bounded_integers.pxd.in
Processing numpy/random\bit_generator.pyx
Processing numpy/random\mtrand.pyx
Processing numpy/random_bounded_integers.pyx.in
Processing numpy/random_common.pyx
Processing numpy/random_generator.pyx
Processing numpy/random_mt19937.pyx
Processing numpy/random_pcg64.pyx
Processing numpy/random_philox.pyx
Processing numpy/random_sfc64.pyx
Cythonizing sources
blas_opt_info:
blas_mkl_info:
No module named ‘numpy.distutils._msvccompiler’ in numpy.distutils; trying from distutils
customize MSVCCompiler
libraries mkl_rt not found in [‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib’, ‘C:\’, ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\libs’]
NOT AVAILABLE
blis_info:
libraries blis not found in [‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib’, ‘C:\’, ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\libs’]
NOT AVAILABLE
openblas_info:
libraries openblas not found in [‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib’, ‘C:\’, ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\libs’]
get_default_fcompiler: matching types: ‘[‘gnu’, ‘intelv’, ‘absoft’, ‘compaqv’, ‘intelev’, ‘gnu95’, ‘g95’, ‘intelvem’, ‘intelem’, ‘flang’]’
customize GnuFCompiler
Could not locate executable g77
Could not locate executable f77
customize IntelVisualFCompiler
Could not locate executable ifort
Could not locate executable ifl
customize AbsoftFCompiler
Could not locate executable f90
customize CompaqVisualFCompiler
Could not locate executable DF
customize IntelItaniumVisualFCompiler
Could not locate executable efl
customize Gnu95FCompiler
Could not locate executable gfortran
Could not locate executable f95
customize G95FCompiler
Could not locate executable g95
customize IntelEM64VisualFCompiler
customize IntelEM64TFCompiler
Could not locate executable efort
Could not locate executable efc
customize PGroupFlangCompiler
Could not locate executable flang
don’t know how to compile Fortran code on platform ‘nt’
NOT AVAILABLE
atlas_3_10_blas_threads_info:
Setting PTATLAS=ATLAS
libraries tatlas not found in [‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib’, ‘C:\’, ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\libs’]
NOT AVAILABLE
atlas_3_10_blas_info:
libraries satlas not found in [‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib’, ‘C:\’, ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\libs’]
NOT AVAILABLE
atlas_blas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in [‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib’, ‘C:\’, ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\libs’]
NOT AVAILABLE
atlas_blas_info:
libraries f77blas,cblas,atlas not found in [‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib’, ‘C:\’, ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\libs’]
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\numpy_45b3cc41e623428693baaa43a0506bab\numpy\distutils\system_info.py:1914: UserWarning:
Optimized (vendor) Blas libraries are not found.
Falls back to netlib Blas library which has worse performance.
A better performance should be easily gained by switching
Blas library.
if self._calc_info(blas):
blas_info:
libraries blas not found in [‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib’, ‘C:\’, ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\libs’]
NOT AVAILABLE
Blas (BLAS (Basic Linear Algebra Subprograms)) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [blas]) or by setting
the BLAS environment variable.
blas_src_info:
NOT AVAILABLE
Blas (BLAS (Basic Linear Algebra Subprograms)) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [blas_src]) or by setting
the BLAS_SRC environment variable.
NOT AVAILABLE
non-existing path in ‘numpy\distutils’: ‘site.cfg’
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
openblas_lapack_info:
NOT AVAILABLE
openblas_clapack_info:
libraries openblas,lapack not found in [‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib’, ‘C:\’, ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\libs’]
NOT AVAILABLE
flame_info:
libraries flame not found in [‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib’, ‘C:\’, ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\libs’]
NOT AVAILABLE
atlas_3_10_threads_info:
libraries lapack_atlas not found in C:\Users\LG\AppData\Local\Programs\Python\Python310\lib
libraries tatlas,tatlas not found in C:\Users\LG\AppData\Local\Programs\Python\Python310\lib
libraries lapack_atlas not found in C:\Users\LG\AppData\Local\Programs\Python\Python310\libs
libraries tatlas,tatlas not found in C:\Users\LG\AppData\Local\Programs\Python\Python310\libs
<class ‘numpy.distutils.system_info.atlas_3_10_threads_info’>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in C:\Users\LG\AppData\Local\Programs\Python\Python310\lib
libraries satlas,satlas not found in C:\Users\LG\AppData\Local\Programs\Python\Python310\libs
<class ‘numpy.distutils.system_info.atlas_3_10_info’>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in C:\Users\LG\AppData\Local\Programs\Python\Python310\lib
libraries ptf77blas,ptcblas,atlas not found in C:\Users\LG\AppData\Local\Programs\Python\Python310\libs
<class ‘numpy.distutils.system_info.atlas_threads_info’>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in C:\Users\LG\AppData\Local\Programs\Python\Python310\lib
libraries f77blas,cblas,atlas not found in C:\Users\LG\AppData\Local\Programs\Python\Python310\libs
<class ‘numpy.distutils.system_info.atlas_info’>
NOT AVAILABLE
lapack_info:
libraries lapack not found in [‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib’, ‘C:\’, ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\libs’]
NOT AVAILABLE
C:\Users\Public\Documents\ESTsoft\CreatorTemp\pip-install-8l886o1k\numpy_45b3cc41e623428693baaa43a0506bab\numpy\distutils\system_info.py:1748: UserWarning:
Lapack (LAPACK — Linear Algebra PACKage) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
return getattr(self, ‘calc_info{}’.format(name))()
lapack_src_info:
NOT AVAILABLE
Lapack (LAPACK — Linear Algebra PACKage) sources not found.
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
NOT AVAILABLE
numpy_linalg_lapack_lite:
FOUND:
language = c
define_macros = [(‘HAVE_BLAS_ILP64’, None), (‘BLAS_SYMBOL_SUFFIX’, ‘64_’)]
C:\Users\LG\AppData\Local\Programs\Python\Python310\lib\distutils\dist.py:274: UserWarning: Unknown distribution option: ‘define_macros’
warnings.warn(msg)
running dist_info
running build_src
build_src
building py_modules sources
creating build
creating build\src.win-amd64-3.10
creating build\src.win-amd64-3.10\numpy
creating build\src.win-amd64-3.10\numpy\distutils
building library “npymath” sources
error: Microsoft Visual C++ 14.0 is required. Get it with “Build Tools for Visual Studio”: Visual Studio & VS Code Downloads for Windows, Mac, Linux
WARNING: Discarding https://files.pythonhosted.org/packages/cb/c0/7b3d69e6ee68bc54c97ba51f8c3c3e43ff1dbc7bd97347cc19a1f944e60a/numpy-1.19.3.zip#sha256=35bf5316af8dc7c7db1ad45bec603e5fb28671beb98ebd1d65e8059efcfd3b72 (from Links for numpy) (requires-python:>=3.6). Command errored out with exit status 1: ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\python.exe’ ‘C:\Users\LG\AppData\Local\Programs\Python\Python310\lib\site-packages\pip_vendor\pep517\in_process_in_process.py’ prepare_metadata_for_build_wheel ‘C:\Users\Public\Documents\ESTsoft\CreatorTemp\tmpgwf2bnvn’ Check the logs for full command output.
ERROR: Could not find a version that satisfies the requirement numpy==1.19.3 (from mfix) (from versions: 1.3.0, 1.4.1, 1.5.0, 1.5.1, 1.6.0, 1.6.1, 1.6.2, 1.7.0, 1.7.1, 1.7.2, 1.8.0, 1.8.1, 1.8.2, 1.9.0, 1.9.1, 1.9.2, 1.9.3, 1.10.0.post2, 1.10.1, 1.10.2, 1.10.4, 1.11.0, 1.11.1, 1.11.2, 1.11.3, 1.12.0, 1.12.1, 1.13.0rc1, 1.13.0rc2, 1.13.0, 1.13.1, 1.13.3, 1.14.0rc1, 1.14.0, 1.14.1, 1.14.2, 1.14.3, 1.14.4, 1.14.5, 1.14.6, 1.15.0rc1, 1.15.0rc2, 1.15.0, 1.15.1, 1.15.2, 1.15.3, 1.15.4, 1.16.0rc1, 1.16.0rc2, 1.16.0, 1.16.1, 1.16.2, 1.16.3, 1.16.4, 1.16.5, 1.16.6, 1.17.0rc1, 1.17.0rc2, 1.17.0, 1.17.1, 1.17.2, 1.17.3, 1.17.4, 1.17.5, 1.18.0rc1, 1.18.0, 1.18.1, 1.18.2, 1.18.3, 1.18.4, 1.18.5, 1.19.0rc1, 1.19.0rc2, 1.19.0, 1.19.1, 1.19.2, 1.19.3, 1.19.4, 1.19.5, 1.20.0rc1, 1.20.0rc2, 1.20.0, 1.20.1, 1.20.2, 1.20.3, 1.21.0rc1, 1.21.0rc2, 1.21.0, 1.21.1, 1.21.2, 1.21.3, 1.21.4, 1.21.5, 1.22.0rc1, 1.22.0rc2, 1.22.0rc3, 1.22.0, 1.22.1)
ERROR: No matching distribution found for numpy==1.19.3
