When I set a heat flux value to a wall of 3D fluidized bed, the program stopped running and showed the following error message. Does this mean MFIX-DEM is not allowing us to set constant heat flux boundary condition? Thank you very much.
Error 1100: The energy equation boundary condition 5 is ill defined for solids 1. Walls can be adiabatic or have a specified temperature for DEM. Please correct the project settings.
Thank you, @cgw! I was trying to paste my project files here. But the software and related project files were crashed after applying constant heat flux BCs. The error message is as follows.
ERROR from check_data\check_bc_walls.f:551 Error 1100: The energy equation boundary condition 4 is ill defined for solids 1. Walls can be adiabatic or have a specified temperature for DEM. Please correct the project settings.
Does this mean we cannot set constant heat flux BC in DEM? Have you tried to establish solid conduction problem in DEM? Thank you.
