Cannot install the MFiX 24.1 in Win_10
Sorry that I have tried several times to install the MFiX but failed. I have used the Miniforge 23.3.1 and tried to install the MFiX 24.1, but had the “403 failed” information.
(base) C:\Users\win10>mamba create -n mfix-24.1 mfix==24.1 mfix-doc==24.1 mfix-gui==24.1 mfix-solver==24.1 mfix-src==24.1 -c conda-forge -c https://mfix.netl.doe.gov/s3/4a03a616/e72825077e6f20d6a817263a62ad4611//conda/dist
              __    __    __    __
/ / \ / \ / \ / \ ____
/ / _/ _/ _/ \ o _,
/ / _
__/ `
    mamba (1.4.2) supported by @QuantStack
    GitHub:  https://github.com/mamba-org/mamba
    Twitter: https://twitter.com/QuantStack
Looking for: [‘mfix==24.1’, ‘mfix-doc==24.1’, ‘mfix-gui==24.1’, ‘mfix-solver==24.1’, ‘mfix-src==24.1’]
https://mfix.netl.doe.gov/s3/4a03a616/e72825077e… 403 failed 1.5s
Multi-download failed. Reason: Transfer finalized, status: 403 [https://mfix.netl.doe.gov/s3/4a03a616/e72825077e6f20d6as
  File "C:\Users\win10\miniforge3\lib\site-packages\conda\exceptions.py", line 1132, in __call__
    return func(*args, **kwargs)
  File "C:\Users\win10\miniforge3\lib\site-packages\mamba\mamba.py", line 941, in exception_converter
    raise e
  File "C:\Users\win10\miniforge3\lib\site-packages\mamba\mamba.py", line 934, in exception_converter
    exit_code = _wrapped_main(*args, **kwargs)
  File "C:\Users\win10\miniforge3\lib\site-packages\mamba\mamba.py", line 892, in _wrapped_main
    result = do_call(parsed_args, p)
  File "C:\Users\win10\miniforge3\lib\site-packages\mamba\mamba.py", line 758, in do_call
    exit_code = create(args, parser)
  File "C:\Users\win10\miniforge3\lib\site-packages\mamba\mamba.py", line 632, in create
    return install(args, parser, "create")
  File "C:\Users\win10\miniforge3\lib\site-packages\mamba\mamba.py", line 499, in install
    index = load_channels(pool, channels, repos)
  File "C:\Users\win10\miniforge3\lib\site-packages\mamba\utils.py", line 129, in load_channels
    index = get_index(
  File "C:\Users\win10\miniforge3\lib\site-packages\mamba\utils.py", line 110, in get_index
    is_downloaded = dlist.download(api.MAMBA_DOWNLOAD_FAILFAST)
RuntimeError: Multi-download failed. Reason: Transfer finalized, status: 403 [https://mfix.netl.doe.gov/s3/4a03a616s
$ C:\Users\win10\miniforge3\Scripts\mamba create -n mfix-24.1 mfix==24.1 mfix-doc==24.1 mfix-gui==24.1 mfix-solver==24
environment variables:
CIO_TEST=
CONDA_DEFAULT_ENV=base
CONDA_EXE=C:\Users\win10\miniforge3\condabin..\Scripts\conda.exe
CONDA_EXES=“C:\Users\win10\miniforge3\condabin..\Scripts\conda.exe”
CONDA_PREFIX=C:\Users\win10\miniforge3
CONDA_PROMPT_MODIFIER=(base)
CONDA_PYTHON_EXE=C:\Users\win10\miniforge3\python.exe
CONDA_ROOT=C:\Users\win10\miniforge3
CONDA_SHLVL=1
CURL_CA_BUNDLE=
HOMEPATH=\Users\win10
LD_PRELOAD=
MIC_LD_LIBRARY_PATH=C:\Program Files (x86)\Common Files\Intel\Shared
Libraries\compiler\lib\mic
PATH=C:\Users\win10\miniforge3;C:\Users\win10\miniforge3\Library\mingw-
w64\bin;C:\Users\win10\miniforge3\Library\usr\bin;C:\Users\win10\minif
orge3\Library\bin;C:\Users\win10\miniforge3\Scripts;C:\Users\win10\min
iforge3\bin;C:\Users\win10\miniforge3\condabin;C:\Program
Files\Microsoft MPI\Bin;C:\Program Files
(x86)\Intel\oneAPI\mpi\latest\bin;C:\Program Files
(x86)\Intel\oneAPI\mpi\latest\bin\release;C:\Program Files
(x86)\Intel\oneAPI\mpi\latest\libfabric\bin;C:\Program Files
(x86)\Intel\oneAPI\mpi\latest\libfabric\bin\utils;C:\Program Files
(x86)\Intel\oneAPI\tbb\latest\redist\intel64\vc_mt;C:\Program Files
(x86)\Intel\oneAPI\tbb\latest\redist\ia32\vc_mt;C:\Program Files (x86)
\Intel\oneAPI\compiler\latest\windows\redist\intel64_win\compiler;C:\P
rogram Files (x86)\Intel\oneAPI\compiler\latest\windows\redist\ia32_wi
n\compiler;C:\Program Files (x86)\Intel\MPI-
RT\4.0.2.005\em64t\bin;C:\Program Files (x86)\Intel\MPI-
RT\4.0.2.005\ia32\bin;D:\VWMare 17\bin;C:\Program Files (x86)\Common
Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Windows\system
32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowe
rShell\v1.0;C:\Windows\System32\OpenSSH;C:\Program Files (x86)\NVIDIA
Corporation\PhysX\Common;C:\Program Files\NVIDIA Corporation\NVIDIA
NvDLISR;D:\matlab 2022a\bin;.;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOW
S\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0;C:\WINDOWS
System32\OpenSSH;C:\Program Files\dotnet;C:\Users\win10\AppData\Local
Programs\Python\Python310\Scripts;C:\Users\win10\AppData\Local\Program
s\Python\Python310;C:\Users\win10\AppData\Local\Microsoft\WindowsApps;
PSMODULEPATH=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\Windows
PowerShell\v1.0\Modules
REQUESTS_CA_BUNDLE=
SSL_CERT_FILE=
 active environment : base
active env location : C:\Users\win10\miniforge3
        shell level : 1
   user config file : C:\Users\win10\.condarc
populated config files : C:\Users\win10\miniforge3.condarc
conda version : 23.3.1
conda-build version : not installed
python version : 3.10.12.final.0
virtual packages : __archspec=1=x86_64
__cuda=12.2=0
__win=0=0
base environment : C:\Users\win10\miniforge3 (writable)
conda av data dir : C:\Users\win10\miniforge3\etc\conda
conda av metadata url : None
channel URLs : conda-forge/win-64
conda-forge/noarch
https://mfix.netl.doe.gov/s3/4a03a616/e72825077e6f20d6a817263a62ad4611//conda/dist/win-64
https://mfix.netl.doe.gov/s3/4a03a616/e72825077e6f20d6a817263a62ad4611//conda/dist/noarch
package cache : C:\Users\win10\miniforge3\pkgs
C:\Users\win10.conda\pkgs
C:\Users\win10\AppData\Local\conda\conda\pkgs
envs directories : C:\Users\win10\miniforge3\envs
C:\Users\win10.conda\envs
C:\Users\win10\AppData\Local\conda\conda\envs
platform : win-64
user-agent : conda/23.3.1 requests/2.31.0 CPython/3.10.12 Windows/10 Windows/10.0.22631
administrator : False
netrc file : None
offline mode : False
Hi @Chichu - sorry for not replying sooner.
Error code 403 means “forbidden” which suggests that perhaps you were using an expired download link - note that the download links are time-limited so you may have to go back to mfix.netl.doe.gov and get a fresh download link
Please let us know if you are contiuning to have trouble with installation, or if you have installed MFiX successfully! Thanks.
Thank you so much. I have successfully installed MFiX.
