I was using mfix the other day, and shut it down as normal.
The next time I try to open mfix, it will not open and the following error appears. Could anybody help me as to why it will not open?
Last login: Wed Dec 9 12:36:01 on ttys000
(base) Chloes-MacBook-Pro:~ chloegriffin$ conda activate mfix-20.2.0
(mfix-20.2.0) Chloes-MacBook-Pro:~ chloegriffin$ mfix
python3.7(8369,0x7fff8e320380) malloc: *** mach_vm_map(size=10402611200) failed (error code=4)
*** error: can’t allocate region
*** set a breakpoint in malloc_error_break to debug
QWidget::paintEngine: Should no longer be called
QPainter::begin: Paint device returned engine == 0, type: 1
Segmentation fault: 11
