Cannot restart DEM
I ran on a cluster a 3D polydisperse DEM simulation with over 2 million particles (with air as a fluid), and when doing a restart_1, I have the following error:
Fatal error in PMPI_Wait: Message truncated, error stack:
PMPI_Wait(219)…: MPI_Wait(request=0x47a60750, status=0x3c32550) failed
MPIR_Wait_impl(100)…: fail failed
MPID_nem_gen2_module_iStartContigMsg(438): Message from rank 180 and tag 5 truncated; 46739176 bytes received but buffer size is 46098720
I have never had an issue like this. Has anyone an idea what is wrong here? (Restart_2 also does not work)
Thanks
Answering my own question … in case it helps someone else
By luck i figured that it was a Dynamic Load Balance issue. When having DBL_DT = … in the *.mfx it had the issue stated. It worked without.
Should be DLB_DT instead of DBL_DT
I did not include DLB_DT, yet I face the same issue. Do you have an idea why that is?
what mfix version have been using? share the .mfx and .f (and particle input file) so that someone can test it on their end please.
I made a post about it here
