Hello there,
My account is approved today, and I try to install nodeworks via conda, the command line is
conda install nodeworks -c https://mfix.netl.doe.gov/s3/e8...d1/89c980...17541/conda/dist
And it comes up
Collecting package metadata (current_repodata.json): done
Solving environment: failed with initial frozen solve. Retrying with flexible solve.
Collecting package metadata (repodata.json): done
PackagesNotFoundError: The following packages are not available from current channels:
- nodeworks
Current channels:
- https://mfix.netl.doe.gov/s3/e8...d1/89c980...17541/conda/dist/osx-64
- https://mfix.netl.doe.gov/s3/e8...d1/89c980...17541/conda/dist/noarch
What should I do?
Strange, that packages are there, what conda environment are you trying to install it into? I did just install it into a mfix environment, but it pulled nodeworks version 17.1.1 instead of the latest.
> conda search -c https://mfix.netl.doe.gov/s3/.../.../conda/dist | grep nodeworks
nodeworks 17.1.0 py_0 s3/.../.../conda/dist
nodeworks 17.1.1 py_0 s3/.../.../conda/dist
nodeworks 19.1.0 pyhcfc1826_0 s3/.../.../conda/dist
nodeworks 19.1.1 pyhe23cd3a_0 s3/.../.../conda/dist
nodeworks 20.1.0 py_0 s3/.../.../conda/dist
nodeworks 20.1.0 pyh22c4f0f_0 s3/.../.../conda/dist
nodeworks 20.1.1 py_0 s3/.../.../conda/dist
nodeworks 20.2.0 py_0 s3/.../.../conda/dist
nodeworks 22.1.0 py_0 s3/.../.../conda/dist
maybe it is not finding the dependencies and conda is providing an errant message. Try adding the conda-forge channel to your install command:
conda install nodeworks -c https://mfix.netl.doe.gov/s3.../.../conda/dist -c conda-forge
onlyjus:
conda-forge
My conda is the miniconda3 on macos, and the detailed info
conda info
active environment : nodeworks
active env location : /Users/apple/opt/miniconda3/envs/nodeworks
shell level : 2
user config file : /Users/apple/.condarc
populated config files : /Users/apple/.condarc
conda version : 4.14.0
conda-build version : not installed
python version : 3.9.12.final.0
virtual packages : __osx=10.16=0
__unix=0=0
__archspec=1=x86_64
base environment : /Users/apple/opt/miniconda3 (writable)
conda av data dir : /Users/apple/opt/miniconda3/etc/conda
conda av metadata url : None
channel URLs : https://mirrors.tuna.tsinghua.edu.cn/anaconda/cloud/conda-forge/osx-64 (offline)
https://mirrors.tuna.tsinghua.edu.cn/anaconda/cloud/conda-forge/noarch (offline)
package cache : /Users/apple/opt/miniconda3/pkgs
/Users/apple/.conda/pkgs
envs directories : /Users/apple/opt/miniconda3/envs
/Users/apple/.conda/envs
platform : osx-64
user-agent : conda/4.14.0 requests/2.27.1 CPython/3.9.12 Darwin/21.6.0 OSX/10.16
UID:GID : 501:20
netrc file : None
offline mode : True
And I also add conda-forge channel and try it, no lucky
I open the link https://mfix.netl.doe.gov/s3/<key>/conda/dist/osx-64 in chrome browser, and get the message:
<Error>
<script type="text/javascript" src="chrome-extension://nhpjggchkhnlbgdfcbgpdpkifemomkpg/pageScripts/main.js"/>
<Code>NoSuchKey</Code>
<Message>The specified key does not exist.</Message>
<Key>osx-64</Key>
<RequestId>AGJ6KQZV76KZ2VGE</RequestId>
<HostId>aHqLkteOReucQamIDLVzdOSaXpMTR3nMw7eTBUn0FTCDF2Ps3lt5bSFn1z4osjqMtWeXW3Psu24=</HostId>
</Error>
can you try:
maybe your key is not working?
It works now. It is the problem on my side, I’ve turned on the offline mode for conda
Thanks and appreciate your time!
opps. I am glad you figured it out!
