Hello everyone,
I have a problem running MFiX 19.3.1 on CentOS 7.7. I tried both the Conda env and building from source.
Using Conda when I launch MFiX I get:
ERROR: In …/Rendering/OpenGL2/vtkOpenGLRenderWindow.cxx, line 754
vtkXOpenGLRenderWindow (0x558d41d8c850): Unable to find a valid OpenGL 3.2 or later implementation. Please update your video card driver to the latest version. If you are using Mesa please make sure you have version 11.2 or later and make sure your driver in Mesa supports OpenGL 3.2 such as llvmpipe or openswr. If you are on windows and using Microsoft remote desktop note that it only supports OpenGL 3.2 with nvidia quadro cards. You can use other remoting software such as nomachine to avoid this issue.
Segmentation fault (core dumped)
And building from source, I got stuck at:
raise Exception(“Unable to find MFIX_HOME in %s” % list(_mfix_homes()))
Exception: Unable to find MFIX_HOME in []
Will you please help me identify the problem in both cases?
Let me know if further system info is needed.
Also mfix-help@mfix.netl.doe.gov seems not working.
