Hi all,
I updated the new version of MFiX and tried to run a simulation that could run in the older version. But I ran in to the following error. From my interpretation it says my whole IC region was defined wrong? Does anyone know what is causing it? Thanks! I attached my mfx and f files as well. Also the way how I submitted the job was
build_mfixsolver --batch --dmp
mpirun -np 28 ./mfixsolver -f td_jelly_roll.mfx NODESI=4 NODESJ=7
Not sure if the way how I submitted the job caused the problem.
BUILD SUCCESSFUL
Error 2000: Unable to process line 209 of the project file.
IC_DES_FIT_TO_REGION(3) = .FALSE.
Possible causes are
- Incorrect or illegal keyword format
- Unknown or mistyped name
- The dimensioned item is too small (array overflow).
Please see the user documentation for this keyword.
td_jelly_roll (6).mfx (21.7 KB)
usr_rates (11).f (3.0 KB)
