Hi all,
I’m working on a simple case of invert trap with particles inside.
The case is uploaded here.
I don’t know why it simply exits without providing any error messages.
I’m quite new to MFIX. Please help.
Thanks!
Hi all,
Thanks!
When I run your case on my system, I see the error:
Operating system error: Cannot allocate memory
Allocation would exceed memory limit
Your mesh may be too fine, requiring too much memory for your system.
Thanks for your reply.
Howevev, I tried to decrease the number of mesh, but got the same problem without any error message.
Could you also try to run with less mesh?
Thanks
There are multiple things are not well defined.
Thank you very much!
Your reply helps me solve this problem.
It’s just because there are too many particles.
You can try PIC instead of DEM.
