Dear MFIX Support Team,
Hello. I am currently working on a CFD-DEM simulation of a spouted bed that we have built in our laboratory. However, I have encountered a challenge and would greatly appreciate your guidance.
In our setup, there are draft plates installed inside the bed, each with a thickness of 1 mm, which matches our experimental device. The particles used in the simulation have a diameter of 3 mm. In order to accurately capture the effect of these thin plates, I need to refine the mesh to a thickness of around 1 mm near the plates (I am using control points for mesh refinement).
However, when I try to run the simulation, I receive a Error from MFIX stating that the mesh size is smaller than the particle diameter, which is technically correct. I understand this limitation, but I was wondering if there are any suggested workarounds or shared experiences from the community on how to deal with such thin internal structures in CFD-DEM simulations.
Any suggestions or recommendations would be highly appreciated.
Thank you very much for your time and support.
