Hello
Whenever I start a new project, I find that the chemistry tab is grayed out. How can I enable it?
Thanks a lot.
Hello
Thanks a lot.
To enable the chemistry pane, you need at least two species defined (fluid + solid).
For example, go to the fluid pane and add O2 and N2. The Chemistry pane will then be enabled.
Thank you very much. I would like to ask if you have got an MFiX tutorial that involves chemical reactions with user defined functions.I coudn’t find any in the user guide.
Thanks in advance
