Hello, researcher. At present, I want to set the gas inlet of 8 circular arrays on a cylindrical model ( which needs to be expanded to 80 in the future ), and I am implementing it through UDF. At present, the solver has been successfully compiled, but it will report errors after running. I don 't know where the problem is. Please take time to look at it. Thank you.
CG_MI boundary conditions require a matching STL file. This is why the solver is looking for geometry_0010.stl This would normally be created by the GUI when you set up the BC geometry.
Boundary condition 10 is not showing up in the GUI:
Since Region seems to define only the plane parallel to the coordinate axis, the curved surface cannot be defined. Therefore, I want to limit the size and coordinates through UDF to define curved surface. It should be clear that I did not add another stl file (geometry_0010.stl). I just wrote the following files.
In addition, I also tried to import the stl file directly to define these inlets (curved surfaces). Specifically, in Geometry, I imported two stl files, one file is the cylinder body (except the inlets surface), and one file is the inlets surface, which is convenient for me to define the boundary conditions. But the model also encountered problems.Mfix seems to force the mass inflow I set to be converted into a wall. As a result, the model does not have any gas injection.
