I was checking usr_rates file of the coal combustion case to use for my case and I saw on line 85:
! Compute gas phase partial pressures (atm)
Pg_atm = P_g(IJK) / 1.013d6
Should not it be d5? 1atm = 101325 Pa?
Are you referencing the SpoutedBedCombustor case under the legacy_tutorials directory? If so, this case uses CGS units where pressure has units of Barye not Pascal.
That case uses CGS units too.
Thanks for the explanation. Is there a way to control (turn on/off) this automatic conversion for the future?
The GUI only supports SI units. We are trying to move away from CGS.
