I was trying the new MFIX on our cluster, and noticed that I cannot compile in serial, smp or dmp.
Here is an example:
(mfix-21.3) [ebreard@talapas-ln2 fluid_bed_tfm_2d]$ module load intel/17
(mfix-21.3) [ebreard@talapas-ln2 fluid_bed_tfm_2d]$ module load intel-mpi
(mfix-21.3) [ebreard@talapas-ln2 fluid_bed_tfm_2d]$ export FC=mpif90
(mfix-21.3) [ebreard@talapas-ln2 fluid_bed_tfm_2d]$ build_mfixsolver --batch -j --dmp
Building custom solver for fluid_bed_tfm_2d.mfx
Running cmake command:
cmake -DENABLE_MPI=1 -G Unix Makefiles -DCMAKE_INSTALL_PREFIX=/gpfs/projects/dufeklab/ebreard/MFIX-21.3/fluid_bed_tfm_2d -DUDF_DIR=/gpfs/projects/dufeklab/ebreard/MFIX-21.3/fluid_bed_tfm_2d -DVERSION=21.3 /projects/dufeklab/ebreard/anaconda3/envs/mfix-21.3/share/mfix/src
– Build type = RelWithDebInfo
– CMake version = 3.19.6
– Fortran compiler =
– Fortran flags =
– ENABLE_MPI = 1
– ENABLE_OpenMP = OFF
– ENABLE_CTEST = OFF
– ENABLE_COVERAGE = OFF
– The Fortran compiler identification is GNU 4.8.5
– Check for working Fortran compiler: /packages/intel/17/linux/mpi/intel64/bin/mpif90 - skipped
– Checking whether /packages/intel/17/linux/mpi/intel64/bin/mpif90 supports Fortran 90
– Checking whether /packages/intel/17/linux/mpi/intel64/bin/mpif90 supports Fortran 90 - yes
– Found MPI_Fortran: /packages/intel/17/linux/mpi/intel64/bin/mpif90 (found version “3.1”)
– Found MPI: TRUE (found version “3.1”)
– Found Git: /projects/dufeklab/ebreard/anaconda3/envs/mfix-21.3/bin/git (found version “2.33.0”)
– Configuring done
– Generating done
– Build files have been written to: /gpfs/projects/dufeklab/ebreard/MFIX-21.3/fluid_bed_tfm_2d/build
Build command:
cmake --build . --target install -j 4
Scanning dependencies of target mfixcore
[ 1%] Building Fortran object model/CMakeFiles/mfixcore.dir/param_mod.f.o
[ 1%] Building Fortran object model/CMakeFiles/mfixcore.dir/funits_mod.f.o
[ 1%] Building Fortran object model/CMakeFiles/mfixcore.dir/dmp_modules/compar_mod.f.o
[ 2%] Building Fortran object model/CMakeFiles/mfixcore.dir/param1_mod.f.o
gfortran: error: unrecognized command line option ‘-ffpe-summary=none’
gmake[2]: *** [model/CMakeFiles/mfixcore.dir/param_mod.f.o] Error 1
gmake[2]: *** Waiting for unfinished jobs…
gmake[2]: *** [model/CMakeFiles/mfixcore.dir/funits_mod.f.o] Error 1
gmake[2]: *** [model/CMakeFiles/mfixcore.dir/dmp_modules/compar_mod.f.o] Error 1
gmake[2]: *** [model/CMakeFiles/mfixcore.dir/param1_mod.f.o] Error 1
gmake[1]: *** [model/CMakeFiles/mfixcore.dir/all] Error 2
gmake: *** [all] Error 2
BUILD FAILED
I tried in serial & smp through the GUI (with and without the parallel option) and I see the same error:
gfortran: error: unrecognized command line option ‘-ffpe-summary=none’.
I can run and compile MFIX-21.1.4 without issue with the same step (DMP as shown above).
Thanks for the help!
E
