Building a custom solver for the Silane Pyrolysis example. Getting an error about ENABLE_PYMFIX=ON. Do I have to deactivate it? and if so how? (I couldn’t find any similar flag, yet). Thanks
Building custom solver for SP2D.mfx
Running cmake command:cmake -DENABLE_PYMFIX=ON -G Unix Makefiles -DVERSION=18.1.5.post0 /lustre/projects/MKOPSCQ/opt/anaconda3/envs/mfix-18.1/share/mfix/src -DUDF_DIR=/lustre/home/kokakos14/MFix/SP2D
– The C compiler identification is Cray 8.7
– The Fortran compiler identification is Cray 8.7
– Cray Programming Environment 2.5.14 C
– Check for working C compiler: /opt/cray/pe/craype/2.5.14/bin/cc
– Check for working C compiler: /opt/cray/pe/craype/2.5.14/bin/cc – works
– Cray Programming Environment 2.5.14 Fortran
– Check for working Fortran compiler: /opt/cray/pe/craype/2.5.14/bin/ftn
– Check for working Fortran compiler: /opt/cray/pe/craype/2.5.14/bin/ftn – works
– Checking whether /opt/cray/pe/craype/2.5.14/bin/ftn supports Fortran 90
– Checking whether /opt/cray/pe/craype/2.5.14/bin/ftn supports Fortran 90 – yes
– Build type = RelWithDebInfo
– CMake version = 3.5.2
– Fortran compiler = /opt/cray/pe/craype/2.5.14/bin/ftn
– Fortran flags =
– ENABLE_MPI = OFF
– ENABLE_OpenMP = OFF
– ENABLE_NETCDF = OFF
– ENABLE_CTEST = OFF
– ENABLE_COVERAGE = OFF
– Found Git: /usr/bin/git (found version “2.12.3”)
CMake Error at build-aux/cmake/PyMFIX.cmake:4 (message):
ENABLE_PYMFIX is only supported for GNU Fortran compiler
CMakeLists.txt:267 (include)
