DEM case with reactions diverge
Hi, guys,
I want to use the DEM with 2 gas reactions and 2 solid reactions to simulate a 2-D fluidized bed.
case description:
It is a simple case with a gas inlet orifice in the bottom, and pressure outlet in the top. The reacting particles(biomass) is injected from the orifice. Initially there are 98(for testing purpose, I set the number small to avoid spending too much time) sand particles serving as bed materials.
my problem:
It is weird that when I only add 2 gas reactions, the simulation is good; when I
only add 2 solid reactions, it is good as well; HOWEVER, when I add both 4 reactions, it kept diverging.
Here is the case set-up:
silane_pyrolysis_pic_3d_2019-10-18T174245.298872.zip (630.9 KB)
Best regards
I have a few suggestions,
  1. You should do a solid phase check in usr_rates_des.f and make sure only the biomass reacts, not the sand. (PM should be 1).
  2. The injected biomass temperature is very high.
thank you
Could you be more specific about how to make sure only the biomass reacts?
It that means adding a condition statement before defining the des_rates() variable? I.e., something like this:
if ( PM==1)
des_rates(Rs_CO2)=…
HI,
I try to remove the sands and see whether it will diverge or not. Then it stops diverging, but I cannot see the product gas being generated.
Here is the new case file
gas_and_solid_2019-10-22T153911.004027.zip (321.7 KB)
In the usr_rate_des.f, when you calculate the heterogeneous reaction, add if(PM==1).
According to your run log file, GAS_AND_SOLID.log, you only ran it for 0.12710 s and there are only 2 biomass particles, (Total PIP=2), and the particles temperature should still be low, so the reaction is slow now, so my suggestions is run the case longer.
I modified my case.
gas_and_solid_2019-10-23T160010.167358.zip (72.7 KB)
And I tried run the case to 1s, but it is very weird that if I try to inject the CO or CH4 gas from the bottom inlet, it will diverge quickly.
Turn the stiff_chemistry on (stiff_chemistry = .TRUE.)
There are few more things:
  1. heat of reaction: unit is Joules/kmol
  2. Since you use SI unit, make sure the unit of the homogeneous reaction rate in usr_rates.f is kmol/s/m3, and the heterogeneous reaction rate in usr_rate_des.f should be kmol/s.
Following your suggestion, it did stop diverging. Thanks.
But currently the problem is I cannot witness any solid reactions.(the last two reactions)
%E5%9B%BE%E7%89%87
gas_and_solid_2019-10-24T123600.908880.zip (20.6 MB)
I am not quite familar with the stiff_chemistry, but I found only if turned on the stiff_chemistry, it will not diverge.
By the way, I am trying to set up the case with the same simulation conditions of this paper.
CFD-DEM_Xiaoke_2014_Norway.zip (2.3 MB)
I want to start with a simlified version of it : no radiation, no turbulence, small number of particles and inject the product gas of pyrolysis directly.
I found my mistakes:
use 1/12.0 rather than 1/12 in the des_rates defining line
