I have encountered a problem. I want to output the drag force on each particle in DEM. By studying the forums, I inserted three DES_USR_VAR in lines 206-208 of drag_gs_des0.f.
Thank you, here is my input files. No bug report was generated because no errors were reported during the run. Thank you for your help and I hope you can give me some guidance! 1129.zip (15.1 KB)
Ooops, sorry, I should not have posted that git grep command. That will only work if you are an MFiX developer and have checked MFiX out from git. This does not apply for normal MFiX users. You should use plain grep, not git grep.
Also, you have to be in the MFiX source directory, not your project directory, when you do this.
Hello researchers, sorry to bother you again. I opened the terminal directly on the desktop of the Linux system, followed the advice to type the command, and was pleasantly surprised to find that there was a problem. What should I do to solve it?
