In the explicitly_coupled method, the heat transfer coefficient is not calculated at all. Why?
IF(.NOT.FLUID_AT(IJK)) THEN
GAMMAxSA(NP) = ZERO
CONV_Qs(NP) = ZERO
! For explicit coupling, use the heat transfer coefficient calculated
! for the gas phase heat transfer calculations.
ELSEIF(DES_EXPLICITLY_COUPLED) THEN
CONV_Qs(NP) = GAMMAxSA(NP)*(lTg - DES_T_s(NP))
ELSE
! Calculate the heat transfer coefficient.
CALL CALC_GAMMA_DES(NP, GAMMA)
GAMMAxSA(NP) = GAMMA* l4Pi*DES_RADIUS(NP)DES_RADIUS(NP)
! GAMMAX(NP) = 对流传热系数颗粒面积 4pi R2.
! Calculate the rate of heat transfer to the particle
Qcv = GAMMAxSA(NP)*(lTg - DES_T_s(NP))
