I am trying to learn chemistry module for PIC. (Also, i will use on my researches)
I investigated silane_prolysis, spouted bed combustor tutorials and C3M export files. This MFiX file is just for learning setup.
When i run without usr_rates_des.f , chemistry are solved with gas. But that error occur when I add usr_rates_des.
Are there anyone check my user defined functions?
Nit P0 U0 V0 Max res 1 1.0E+01 0. 0. P0 2 3. 7.7E-02 0.2 P0 3 1.3E-04 4.1E-02 0.1 V0 4 3.1E-05 2.2E-02 5.7E-02 V0Program received signal SIGFPE: Floating-point exception - erroneous arithmetic operation.
Backtrace for this error:
5 1.6E-05 1.1E-02 2.9E-02 V0
6 7.8E-06 5.6E-03 1.5E-02 V0
7 3.9E-06 2.8E-03 7.4E-03 V0
8 1.9E-06 1.4E-03 3.7E-03 V0
9 9.7E-07 7.0E-04 1.9E-03 V0
10 4.8E-07 3.5E-04 9.3E-04 V0
11 2.4E-07 1.8E-04 4.7E-04 V0
t= 0.0000 Dt= 0.1000E-06 NIT= 11 Sm= 0.0000 Hl= 0.0000 CPU= 1. s
MbError%(0,MMAX): -0.8352E-14
#0 0x7f5b9ce3fd01 in ???
#1 0x7f5b9ce3eed5 in ???
#2 0x7f5bea33420f in ???
#3 0x7f5b9d54d1ac in usr_rates_des_
at /home/akececi/mfix/silane_pyrolysis_pic_3d_020121/usr_rates_des.f:317
#4 0x7f5b9d8b1db4 in __calc_rrates_des_mod_MOD_calc_rrates_des
at /home/akececi/anaconda3/envs/mfix-20.4.2/share/mfix/src/model/des/calc_rrates_des.f:110
#5 0x7f5b9d6a066a in __rxns_gs_des1_mod_MOD_rxns_gs_gas1
at /home/akececi/anaconda3/envs/mfix-20.4.2/share/mfix/src/model/des/rxns_gs_des1.f:191
#6 0x7f5b9d7b974c in _step_MOD_chem_mass
at /home/akececi/anaconda3/envs/mfix-20.4.2/share/mfix/src/model/time_step.f:212
#7 0x7f5b9d706d85 in run_fluid
at /home/akececi/anaconda3/envs/mfix-20.4.2/share/mfix/src/model/mfix.f:202
#8 0x7f5b9d706d85 in run_mfix
at /home/akececi/anaconda3/envs/mfix-20.4.2/share/mfix/src/model/mfix.f:142
#9 0x7f5b9d549122 in __main_MOD_run_mfix0
at /home/akececi/mfix/silane_pyrolysis_pic_3d_020121/build/pymfix/main.f90:82
#10 0x7f5b9d53c8d6 in f2py_rout_mfixsolver_main_run_mfix0
at /home/akececi/mfix/silane_pyrolysis_pic_3d_020121/build/f2pywrappers/mfixsolvermodule.c:1270
#11 0x557983976cca in _PyObject_FastCallKeywords
at /tmp/build/80754af9/python_1598874792229/work/Objects/call.c:199
#12 0x5579839dc39d in call_function
at /tmp/build/80754af9/python_1598874792229/work/Python/ceval.c:4619
#13 0x5579839dc39d in _PyEval_EvalFrameDefault
at /tmp/build/80754af9/python_1598874792229/work/Python/ceval.c:3093
#14 0x55798396ee7a in function_code_fastcall
at /tmp/build/80754af9/python_1598874792229/work/Objects/call.c:283
#15 0x55798396ee7a in _PyFunction_FastCallKeywords
at /tmp/build/80754af9/python_1598874792229/work/Objects/call.c:408
#16 0x5579839d773f in call_function
at /tmp/build/80754af9/python_1598874792229/work/Python/ceval.c:4616
#17 0x5579839d773f in _PyEval_EvalFrameDefault
at /tmp/build/80754af9/python_1598874792229/work/Python/ceval.c:3110
#18 0x55798396ee7a in function_code_fastcall
#19 0x55798396ee7a in _PyFunction_FastCallKeywords
#20 0x5579839d773f in call_function
#21 0x5579839d773f in _PyEval_EvalFrameDefault
#22 0x55798391f85a in function_code_fastcall
#23 0x55798391f85a in _PyFunction_FastCallDict
at /tmp/build/80754af9/python_1598874792229/work/Objects/call.c:322
#24 0x55798393e4d2 in _PyObject_Call_Prepend
at /tmp/build/80754af9/python_1598874792229/work/Objects/call.c:906
#25 0x557983930ffd in PyObject_Call
at /tmp/build/80754af9/python_1598874792229/work/Objects/call.c:245
#26 0x557983a2ff76 in t_bootstrap
at /tmp/build/80754af9/python_1598874792229/work/Modules/_threadmodule.c:994
#27 0x5579839ea817 in pythread_wrapper
at /tmp/build/80754af9/python_1598874792229/work/Python/thread_pthread.h:174
#28 0x7f5bea4e9608 in start_thread
at /build/glibc-ZN95T4/glibc-2.31/nptl/pthread_create.c:477
#29 0x7f5bea410292 in ???
#30 0xffffffffffffffff in ???
Floating point exception (core dumped)Primary job terminated normally, but 1 process returned
the job to be terminated. The first process to do so was:Process name: [[2141,1],0]
Exit code: 136Previous MFiX run is resumable. Reset job to edit model
MFiX process has stopped
silane_pyrolysis_pic_3d_2021-02-02T084850.313227.zip (102.8 KB)
