Hello MuSaNgO82
I am running sscp-dem.mfx now.
Your setup is a little bit complex - you have a lot of monitors, and the pattern for filenames for the monitors is not clear to me (you’re not doing anything wrong, it’s just a bit confusing).
Let’s look at two of the monitor definitions, number 9 and number 14.
# Monitor 9: v1
monitor_type(9) = 107
monitor_name(9) = 'particle_velocity1'
monitor_dt(9) = 0.001
monitor_vel_x(9) = .True.
monitor_vel_y(9) = .True.
monitor_vel_z(9) = .True.
# Monitor 14: v1
monitor_type(14) = 105
monitor_name(14) = 'granular_temp1'
monitor_dt(14) = 0.001
monitor_vel_x(14) = .True.
monitor_vel_y(14) = .True.
monitor_vel_z(14) = .True.
These both define monitors over the same region v1 (region boundaries elided).
They both monitor particle x,y, and z velocity at the same interval. Monitor 9 is type 107, which is a weighted average, and will write to a file called PARTICLE_VELOCITY1 (since mfix stubbornly upcases all strings in the input file).
Monitor 14 has monitor_type=105 which specifies the standard deviation, as you correctly noted. So the standard deviations of the velocities will be written to the file GRANULAR_TEMP1.
Now, after running the simulation for a few minutes I have the following outputs:
Monitor 9: PARTICLE_VELOCITY1 (averages)
# Run type: NEW
# "Time","vel_x","vel_y","vel_z"
0.0000000 , 0.0000000 , 0.0000000 , 0.0000000
0.10000000E-02, 0.34482017E-04, 0.17258347E-02, -0.50105061E-11
0.20700000E-02, 0.54825847E-04, 0.50110600E-04, -0.82220707E-10
0.30400000E-02, 0.71454240E-04, -0.15001964E-02, -0.19112713E-09
0.40400000E-02, 0.88109975E-04, -0.30777613E-02, -0.31494361E-09
0.50100000E-02, 0.10402533E-03, -0.45872430E-02, -0.43913605E-09
0.60800000E-02, 0.12196800E-03, -0.62794031E-02, -0.58046728E-09
0.70800000E-02, 0.13865305E-03, -0.78405230E-02, -0.71297129E-09
Monitor 14: GRANULAR_TEMP1 (standard deviations)
# Run type: NEW
0.10000000E-02, 0.58721390E-02, 0.41543161E-01, NaN
0.20700000E-02, 0.74044477E-02, 0.70788840E-02, NaN
0.30400000E-02, 0.84530609E-02, NaN, NaN
0.40400000E-02, 0.93866913E-02, NaN, NaN
0.50100000E-02, 0.10199281E-01, NaN, NaN
0.60800000E-02, 0.11043912E-01, NaN, NaN
0.70800000E-02, 0.11775103E-01, NaN, NaN
I’m not sure how you produced the plot you attached, or exactly which pair of monitor definitions those are (or what x/X means) but I don’t see an issue where the standard deviations are equal to the averages. What I do notice is a lot of NaN (not a number) values in the standard deviations, which I don’t understand - if we’re able to calculate an average we should be able to calculate sigma. And why are the NaNs only in the third and fourth columns? I think there may be a problem in the standard deviation calculation in MFiX - I will follow up on this.
I’d like to know more about the plot you posted - which pair of monitors is that? Can you also provide the data files?
Be patient, we’ll get this sorted out
