Hello,developers!
When I run the case, I get a DT<DTmin error at the initial moment, and I’ve tried some of the solutions in the support but it still doesn’t solve the problem.
For example, I resize the grid, set “Maximum iterations” to 200,set the number of iterations to 200 for the gas pressure and uncheck “Detect stall”.
I don’t know what more I can adjust, can you check my case for me?
xiejun.mfx (25.1 KB)
usr_rates.f (3.9 KB)
usr_rates_des.f (5.7 KB)
Does the case run if you disable the chemical reactions?
If the chemical reaction is disabled, the case still does not run.
What version did you use? I tried newest mfix and it did not have the DT issue.
Thanks Renjie, that’s a very good point.
You can see the MFiX version at the top of the .mfx file:
#! File written Mon Jun 10 15:54:31 2024
#! MFiX version 23.3.2 by 18370 on DESKTOP-8TS8PN4
So, @wangjinjing, please upgrade MFiX!
