Yes, using Linux within a virtual machine such as VirtualBox or VMWare on Windows would works. Using WSL2 would also be possible. The performance for a laptop or desktop system in a virtual environment would likely be comparable to running Linux natively on the same hardware (I would guess.)
Hi! I am doing a CFD-DEM simulation of a cylindrical liquid-solid fluidized bed. I have tried the method that @tyurata described and indeed it works, but only with the Hookean collision method. If I try to change it to Hertzian, the program computes one time step, and then it stops without giving any error. Does anybody know if this can be solved? Thanks!
Hi Filippo - can you upload your project files, and weâll have a look? You can use âSubmit bug reportâ to create a zip file containing everything.
- Charles
Hi Charles, thanks for the reply. Here is the zip file.
Filippo
fb-mono_2021-02-18T154147.803473.zip (4.9 MB)
The files you sent work fine with me on Linux. What do you mean by the program âstops without giving any errorâ? It could be running but very slowly with the Hertzian model and a large Youngâs modulus. It takes 36 seconds for the DEM loop to complete on my machine.
Fails to build, for me
/tmp/fb-mono_2021-02-18T154147.803473/calc_collision_wall_mod.f:955:24:
955 | QSWALL = DES_CONDUCTION_WALL(OVERLAP,K_s0(phase_LL), &
| 1
Error: Type mismatch in argument âiâ at (1); passed REAL(8) to INTEGER(4)
gmake[2]: *** [CMakeFiles/udfs.dir/build.make:82: CMakeFiles/udfs.dir/tmp/fb-mono_2021-02-18T154147.803473/calc_collision_wall_mod.f.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:174: CMakeFiles/udfs.dir/all] Error 2
gmake: *** [Makefile:149: all] Error 2
BUILD FAILED
Thatâs gfortran 10.2.0 on Linux. Trying Windows now.
This file is not compatible with the latest MFiX version. It works with 20.2.
@fmarchelli
your file has
!MFIX-GUI OMP_NUM_THREADS = 16
OMP is not supported on Windows. The control in the run popup is disabled:
The âThreadsâ control is disabled but itâs set to 16. How did you get this set to 16?
I suggest removing that line from fb.mfx (edit the file carefully, while not running MFiX, then reload it). Will your job run without this setting?
OpenMP might work on Windows some day, but itâs not supported by us at this time, and would take some work to get going. If you can, run your parallel jobs on Linux!
- Charles
Hi Jeff, thanks for the help, I really think it is stopping, please see this screenshot:
If I follow the exact same procedure but with the Hookean model instead, the simulation works just fine.
@cgw I am not using the GUI and, following the steps described in this thread, I can use 16 threads even on Windows. I understand that it is not supported and thus it may not work in all cases, I will try to run it on Linux. Thanks!
