Error 1<PyQt5. QtNetwork.QNetworkReply object at 0x14fd818c0a60>
Hi, everyone, I am currently experiencing a problem with MFIX-22.3 running on linux. After running for about 10 minutes, the software automatically stops and exits with an error message like the one shown below. I am not sure what caused it now. If you have encountered such mistakes, please help me reply, thank you very much!
123456789_2022-11-24T100929.182104.zip (8.7 MB)
Hi Wanygi -
I am able to reproduce this problem. When the program crashes, we get a core file. Examining that file:
mfix-22.4:) file core
core: ELF 64-bit LSB core file, x86-64, version 1 (SYSV), SVR4-style,
from '/usr/bin/mpirun --use-hwthread-cpus -mca mpi_warn_on_fork 0 -np 8 /tmp/12345678', real uid: 103, effective uid: 103, real gid: 1000, effective gid: 1000, execfn: '/usr/bin/mpirun', platform: 'x86_64'
That is a bit unusual - the core file is not from mfix itself but from mpirun. I’m not used to seeing this. And the bad_alloc message indicates memory allocation problem. But not from MFiX itself - that’s a C++ exception. Did mpirun itself run out of memory?
I should also point out that the NetworkReply message is a red herring - this just means that the solver exited and the GUI was not able to contact the solver process.
Running this again, and looking at top, sorted by resident set size, I think I see the problem:
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
 6433 cgw       23   3 8151968   3.9g 193988 R  64.6  25.5  19:21.77 mfix
 6583 cgw       23   3 1780288 174608  24196 S  89.4   1.1  28:21.70 python
 6585 cgw       23   3 1614356 155728  21008 S  92.4   1.0  27:35.13 python
 6587 cgw       23   3 1614352 155384  20808 S  92.4   1.0  27:26.48 python
 6595 cgw       23   3 1609104 154560  20936 S  95.0   1.0  27:51.38 python
 6589 cgw       23   3 1609104 154368  20988 S  84.1   1.0  27:55.36 python
 6592 cgw       23   3 1609104 154360  20808 S  88.4   1.0  27:45.71 python
 6593 cgw       23   3 1609104 154120  20712 S  95.7   1.0  27:45.15 python
 6596 cgw       23   3 1609104 154020  20700 S  76.5   1.0  27:38.98 python
 6577 cgw       23   3  175576  18656  14936 S   0.3   0.1   0:04.91 mpirun
The process listed as mfix is the GUI itself, the 8 python jobs are the jobs kicked off by mpirun. Neither the solver jobs nor mpirun is using much memory, but over time the memory used by the GUI is growing (memory leak). I’m not sure why this is happening, but eventually the GUI uses so much memory that mpirun is not able to allocate buffers.
I will follow up on this, but since we’re all out of the office next week for the holidays, it might be a while.
I think the problem is just the amount of messages you are printing.
There are a lot of messages like this in the MFiX console:
  DES_RATES(R1)=   0.0000000000000000
and since all the messages in the console are sitting in memory, this is adding up to gigabytes - if I flush the console (x button) the memory usage goes down from 4 to 2GB.
in your
usr_rates_des.f:
         write(*,*)  "k_so=",  k_so
			   write(*,*)  'p_CO2', p_CO2, 'c_CO2', c_CO2
         write(*,*) "C_co2_e=", C_co2_e
         write (*,*) " DES_RATES(R1)=", DES_RATES(R1)
This is fine for debugging but for real runs you need to disable this. If you remove or comment out these lines, you will see that the job runs without problems.
Perhaps we should add code to the GUI to drop messages when the size gets too big. However this could result in losing important information from the beginning of the run so I hesitate to do so.
