Hi, everyone. I met this error while running. I would like to consult you about the possible cause of this and what I need to modify to solve it.Looking forward to your answer!
Summary
suliao_2022-04-28T133717.685693.zip (1.1 MB)
Hi. Running the job here did not lead to ‘NaN detected’. But it failed to converge (DT < DT_MIN).
Note the large number of warnings.
I’m seeing a large number of this warning:
Velocity exceeds limit: 100.00
and this message:
The sum of mass fractions is not equal to one.
Note that you can scroll through the messages with the arrow and TAB keys.
The MAX_INLET_VEL_FAC message has been discussed here before, it most often is due to poor mesh quality. I suggest searching the forum for MAX_INLET_VEL_FAC.
Okay. Thank you very much.
I am running DEM simulation with heat transfer and getting same error " NaN detected in residual:Energy equation, phase (0) " could you please suggest me about the possible cause of this error. my case file is attached here.
fbht.mfx (12.0 KB)
Please try to turn off the DES conduction correction to see if it helps.
okay, I will check with this option. Thank you
