After building the solver, click Run to report an error.Before this error, it could run normally, but after changing the inlet wind speed, it ran into problems. * Looking forward to your reply. Thank you
I changed the subject of your post because it’s not a solver build error (you built the solver successfully), it is a runtime error. If you scroll up a little bit in the console window (lower right) you’ll see this message:
Error 1000: Unable to match particles crossing processor boundaries.
Source Proc: 1 ---> Destination Proc: 0
Global Particle ID: 272
(PE 0) : A fatal error occurred in des routines
Note that this message should be triggering a popup but it’s not, I think because the “MPI_ABORT” message took precedence. I’ll take a look at fixing that. For now you might have to scroll up a bit to make sure you see all the messages:
Next step is to search the forum for terms like DESMPI_UNPACK_PARCROSS and Unable to match particles, this returns a bunch of results including this helpful reply:
