Error 1100: Unphysical gas phase volume fraction calculated
When I try to run a task, I get the following error, what is the reason? How should it be solved?
Error 1100: Unphysical gas phase volume fraction calculated. A .vtp
file will be written and the code will exit. Fluid cell details:
This is a fatal error. A particle output file (vtp) will be written
to aid debugging.
Thanks for your help!
LTRY-ERROR.zip (6.4 MB)
